Tony SD
the HD space! RAW files are killing my 80G HD. I do archive to DVD and a second external, but even so the disk which I thought a year ago would last years is going to last months at this rate!
TonySD
TonySD
comparing a RAW DPP) file and the imbedded JPEG (see the first
post), you can see a lot of what I would call "noise" -- maybe the
correct term is artefacts from the sharpening, but the end effect
is an image which seems to have more noise
RSE doesn't add this amount of "noise" but does add a more
pixel-like noise, esp. to the edges ... EVU adds very little, as
does RIT (just as a comparison)
I want to do a RAW converter comparison with some shots, so I will
have a look into that
AJ
http://www.pbase.com/manjade
Shooting raw has REALLY increased my HD space needs. There's the 10mg for the raw file, and I still usually create the jpg's, then when I do larger than 4x6 prints there's the 25-50mg Tiff or photoshop file.the HD space! RAW files are killing my 80G HD. I do archive to
...Like to emphasise something in the shadows, or change from the poor auto white balance (can you afford the time to do a white balance test shot for each shot or set of shots), or if you want to get a richer print using Adobe colourspace when you had shot in sRGB, or if you want to do a digital blend by creating 2 JPEGs from one raw shot, or....unless the camera you are using has a very poor jpg output,which
some have, and this has been mentioned in reviews. As we know, the
Canon shoots jpeg and raw together,I don't see too much difference
when comparing. The ones who love us using raw the most are the
memory manufactorers.
Shooting raw has REALLY increased my HD space needs. There's thethe HD space! RAW files are killing my 80G HD. I do archive to
photoshop file.
This year's images so far take up 50gig -- that's what all of last
years needed. Multiply that by 2 because I keep a second copy on
an external drive. It starts to add up fast.
I just purchased an internal 300gig hd for $150.
Lee
I would conclude that as well. Only from seeing howI think I suck at RAW conversion.
breathtakingly beautiful your jpg photos are. The only conclusion
I can come to is that "you suck" at converting raw.
I tried and rejected raw several times before finally getting to
where I could really get better photos from the raw. But frankly,
when I see your work I'd say "why bother"?
Lee
Nope. With the raw file, you still have access to all the information that was available at the point of capture. You can change WB, and exposure, contrast and saturation. But it begs the question "if you set these all up the way you wanted at point of capture, what advantage is raw".does this mean that RAW is only really useful for those who do not
convert to JPEG --- I thought most people did this, apart from pros
who need to do print jobs etc
CD's and DVD's do not last forever. Some fail after less than a year. I've looked for and can't even find a brand of DVD that is sold as "archival quality".There is no reason to keep the origingals all on your HD. Back them
up to DVD-R and/or CD-R.
We disagree. My hard drive and hard drive backups are my long term storage solution. Not that any one drive will last forever, but that I'll always be buying and upgrading computers and hard drives and moving my files forward to the latest.In my opinion HD should not be thought of or used for longterm
archival storage.
if converting to .jpg is enough to loose that advantage, then it is not really a big one for me. The simple fact that I also cannot see a difference with the psd file...not only the jpg drive it to the other level that you need to keep it to 16 bits and print it to see the difference..now will that difference be enough for me to rave about raw? not sure. I alwasy printed RAW in 8 bits and found it to be faithfull to life and so was the .jpg.Also, every photo I could show you would have to be done using a
jpg file. The biggest problem with "shooting jpg" is the jpg
format. So if I shoot RAW and convert to jpg in order to show how
much better raw is -- then I'd lose the very advantage I'm trying
to show.
no I don'T. I shoot for the center to protect highlights. it also give me richer colours.You know me...you've seen my posting for a couple years. You
probably saw me struggling with my "soft" soccer photos. I
wouldn't be going through shooting raw and converting a couple
hundred photos Sat. in and out, if I could get as good a results
with jpg....in the same amount of time.
I'm certainly open to the same conclusion about my "jpg processing
skills" that you are with your "raw processing skills" -- mabye "I
just suck at processing jpg".
Do your "shoot to the right"?
problem is that I do have some that are on the right on the histogram sometimes and see no difference either.and aiming for your exposures to snug up agains, but not touch the
right side...as so many sites suggest? I do. The reason given is
that there is far more data captured at that end of the signal.
But I hadn't been adjusting down later. So I had all of these
photos that were over exposed...not blown out, mind you, just over
exposed.
like what color space?I learned this with camera RAW because I could see the 3 color
histogram and found out that even the the "total sum" of colors was
not over exposed, I frequently blew out the red channel. As I back
to the left with the exposure slider "pop" goes my skin tones that
I'd been struggling for so long.
AND -- I learned that I could change color spaces and watch those
"blown out reds" all of a sudden NOT be blown out -- with no
changing of the exposure slider.
I wish I could.I can't prove it to you. I can't look at your photos and say "wow,
if only you shot that in RAW, it really could have been good" --
because your photos are excellent. I can say that I have been
convinced, not because people told me so -- but because I can see
it myself.
--But really -- a well done jpg photo can produce a great print and I
don't debate that. Just as I understand that "L glass" is better,
but the kit lens CAN produce excellent photos as well.
Lee
If I did I'd expose for it....Like to emphasise something in the shadows,
Actually auto WB does a pretty good job mostly. When it is a bit off, then I touch it up in the JPG. As long as it's a minor adjustment, I have no problem.or change from the
Since none of the printing methods I use take advantage of it, I don't bother.or if you want to
sRGB,
Ahhh - sometimes I will do this. In fact, there are other situations where RAW can be a benefit too. Then I look at the camera, wish 3 times that it had RAW capability, and it seems to be able to support RAW after that. So I select it from the menu - for those shots that require or benefit from RAW. Then I change it back. I still shoot JPG almost all the time.or if you want to do a digital blend by creating 2 JPEGs from
I have a 1 GB card - but even if I chose not to, I'd hardly feel I had to justify my spending to you or anyone else.Anyway, if you can't afford another $100 for a 1GB memory card, why
are you spending thousands on a high quality SLR camera and lenses.
I loved this - that's actually why I replied. Making up a lame analogy, then using it as proof does not do anything.Sorta like putting the cheapest film you can buy into a film
camera. JPEG is like the "generic brand" digital film.
Yes I am. If you are happy with RAW, that's good too.Still, if you're happy getting what you can out of JPEG,
I'm not sure how you process JPGs, but I don't have problems with fringing. If you feel better somehow saying they are there, but I can't see them - well that's OK.haven't ever noticed the fringing lines in a blue sky after playing
with the contrast on your JPEGs,
I guess I don't.then you don't value it, and don't
care.
Maybe you don't understand that everyone has their own priorities. If I were you, I'd stop trying to convince everyone they were wrong.Sorta like me trying to convince my wife that the sound from
the home theatre is better than from the TV- she thinks it is but
doesn't care enough to spend money/time on it (I do![]()
--Indulis
CD's and DVD's do not last forever. Some fail after less than aThere is no reason to keep the origingals all on your HD. Back them
My back up dvd's are purly "if my house burns down, at least I have
my photos on dvd at work".
We disagree. My hard drive and hard drive backups are my long termIn my opinion HD should not be thought of or used for longterm
archival storage.
Lee
that'S a 2 sharp-sided knive though. if you don't let the camera do it, then you loose the ability to use the DIGI II fine conversion.Exactly. If you "let the camera do it" -- you lose the ability to
control 'which bits'. If you let the "raw converter" and don't
actually take control of "which bits" -- then you've lost that
advantage.
what I don't understand is why the "as shot" with all different programs give a totaly different output than the "as shot" with the in-camera conversion?Plus if you convert to jpg at all, then you have the limitations of
jpg -- whether you did it "in camera" or in your convertign
software.
Settings have to be applied. Whether you go with "as shot"correct me if I am wrong, but you can't use RAW without changing it
-- is that right?
settings, or whether you hand tweak the settings. But if you don't
"hand tweak" the settings, why would you expect a superior result?
no, all I see is a difference in focusing point because the photos were not taken at the same time. so one could have shake, one could have this ot that problem..they were not taken from the same data so cannot really be compared.Look more carefully and you will see that RAW does have more detail.
----Lee, many people argue that you get more resolution and betterWho argues that there is some superiority to a raw file that is
processed with "no settings changed"?
detail with the raw..problem is, they failed to prove it.
I think we all agree that when there is a problem in exposure, then
the RAW would give better latitude to save it. We all know that
too.
I guess what I and a few other people are trying to find out is, is
there a real advantage to shoot raw for a well exposed
pics..meaning is there a read advantages for each photos that we
shoot, not only the bad ones?
it is still interesting test to also compare RAW converter
program..see how different they are.
--It's when you DO need to adjust wb, or exposure that you see the
advantages.
Lee
Please do not start new thread for private message to me but send
them to me via email instead! thanks.
http://aphoto.smugmug.com/
ok we are talking about the same thing but seeing it differently! ;-)
I see the advanced details, but have had results where DPP has
added "detail/noise" in areas of flat colour (like black curtains
at the back of a play, which suddenly become "noisy")
I do prefer DPP to RSE, as I find it easier to use and the results
easier to attain.
maybe I do need to change the sharpening (I think i had it at 2)
is it worth putting the value to ZERO and doing USM later in PS?
AJ
why spend hundred of $ on CF cards? if you need to shoot raw because the exposure is off or WB is off, then maybe it make more sense to put your money on photography lessons instead of buying more cards to shoot raw..Anyway, if you can't afford another $100 for a 1GB memory card, why
fringing on a blue sky? I never had that problem, not even in prints. what fringing at you talking about?Still, if you're happy getting what you can out of JPEG, and
with the contrast on your JPEGs, then you don't value it, and don't
care.
--the home theatre is better than from the TV- she thinks it is but
Indulis
in deed..look at the eye of that insect? the raw conversion made the highlight in the eye very harsh..it is smooth in the .jpg and will remain smooth in printing:comparing a RAW DPP) file and the imbedded JPEG (see the first
