Bart Hickman
Here's a Paintshop Pro preset I've been using. This is for the "curves" tool found in the menu
"Adjust-> Brightness and Contrast-> Curves..."
Just download the preset and put it in your preset directory--eg.,
C:\Program Files\Jasc Software Inc\Paint Shop Pro 9\Presets
I don't know if it will work with Photoshop. If not, it's an ascii file so Photoshop users can open it in a text editor and copy the coordinates manually if desired.
This preset is based on actual measurements of the transfer curve of my z750 over its full dynamic range (somewhere around 8-9 f-stops) so it'll work for any photo regardless of how bright it is. When you apply it, it will brighten your image by 1-stop. Apply it twice to get 2-stops. This works quite a bit better than the previous method I had described using the level adjust tool.
I'm assuming all z750's would have the same curve. It's easy to test--just take two identical photos 1-stop apart in brightness. Then boost the darker one and see how closely it resembles the brighter one.
This is most useful for doing that virtual ISO1600 I'm always talking about.
Click on the link to view it or right-click to download it.
http://home.comcast.net/~zumbari/Z750_Virtual_ISO1600/Preset_ColorAdjustCurves_z750_plus_1_stop.PspScript
Bart
Bart
