Zane Paxton
I have had the D2x for about a week and have only done one outing where I did a bunch of test shots. Observation: The camera is EXTREMELY intolerant of sloppy technique. The images were softer than expected and I believe that the softness is from camera shake caused by various things.
Using a lightweight tripod or a tripod with the center column extended will accentuate camera shake. I have a Gitzo 1228 CF with a RRS BH-55 Ball Head and had the center column fully extended in one of the fuzziest shots.
I could see obvious "mirror slap" from the camera in the viewfinder in the above scenario. I was amazed by how much. I was shooting with the 70-200mm VR, mounted on the lens collar (with a RRS foot). That setup on top of the extended center column was a bad idea...
F-stops over 11 start to add softness due to light diffraction on the sensor's small photosites (according to Thom Hogan's eBook, worth getting by the way). F/22 was indeed softer that expected....
Soft conditions under the tripod: Some of the softer shots were from a wooden deck with someone else walking on it. One was with the tripod forced into iceplant (not super solid).
Handheld shots. Used to be able to get sharp shots from a wide angle at 1/90th most times if I held my breath and hadn't had any coffee. Not so with the D2x.
Possible mitigations:
I'm going to try hanging my (heavy) camera bag from the hook on the bottom of the center column on my Gitzo 1227 to see if that helps (inertia), keeping the center column all the way down tight (maximum stiffness) and try mirror lock-up before exposures. I'm using a corded electronic shutter release of course.
Fussy for sure; but that looks like the level of discipline that is required. Otherwise, the subtle camera shake will make the resulting images look like images from a 6 mp camera....
Does that match the experience of other D2x users? Any other best practices? Lessons learned?
PS:
My lenses used:
Nikkor 17-35mm AFS
Nikkor 28-70mm AFS
Nikkor 70-200mm VR
Thanks,
Zane
http://www.pbase.com/devonshire
Nikon D2x & Fuji S2
PS:
My lenses used:
Nikkor 17-35mm AFS
Nikkor 28-70mm AFS
Nikkor 70-200mm VR
Thanks,
Zane
Nikon D2x & Fuji S2
