Mike Collins
You didn't mention what you were taking a picture of. If it is routine candid shots of people, then the SIMPLEST thing to do is put the camera in manual, meter the sky, adjust to properly expose the sky, and then use fill flash to fill the shadows. Setting white balance on whatever works for the sky should give an acceptable result. Your profile says you have a DRebel... not sure if it will let you do this or not, but I would think that it would if the camera is in manual.
The key thing about this suggestion is that I believe it is the SIMPLEST. There are many techniques that might yield a different result, but this will work if the difference in exposure between the sky and subject isn't too great. (I realize this won't work for landscapes where the mountains are a mile away... but he didn't mention anything about landscape shots)
Regards, Mike - 1DMkII/D2H/D70
