D
Debbie,How do you view S2 video clips on a DVD player?
Say I have 650mb of S2 videos clips. Can I burn those video files
to a CD-R/RW and view them in my DVD player or is there more to it
than that?
Please explain. Thanks...
--Debbie,How do you view S2 video clips on a DVD player?
than that?
The videos recorded on an S2 are in AVI/Motion JPEG format. On a
computer these videos can be viewed using Windows Media Player,
QuickTime (for Windows or Mac), RealPlayer, etc.. If you burned a
video in this format onto a DVD, it would NOT be viewable on a DVD
player. DVD videos are in MPEG2 format (video compression format),
which a completely different video format.
The only way you'd be able to burn a DVD that can be viewed on a
DVD player would be to convert it to MPEG2 format. That could be
done (not easily) by playing the video (converting it back to an
analog signal) and redigitizing it into MPEG2 format. That would
require an A/D converter (like the Dazzle) connected to your
computer, or a DVD recorder. Of course, this would produce some
image degradation since the digitized image would have to be
converted to analog and then back to digital.
AFAIK there are no direct AVI to MPEG2 converters.
As you can see this is not a simple matter. The easiest way to
view these videos on a TV is to use the camera itself to output a
NTSC signal directly to the TV.
Maybe others have different suggestions.
Good luck.
rag
You can try WINAVI it will convert your files to just about anything
Im sure there are heaps but i use Roxio easy media creator 7Is it possible to burn a dvd that combines photo slideshows and
movies? What would you need to create slideshows, and burn
slideshows and movies to dvd with menus?
JonathanF
