Deja-Vu and Tiger
Dick Lund
Leading Member
Mesa, AZ, US
I just upgraded to tiger and I can't backup anything. I have 5 250 gig HD 2 of which is internal. I installed tiger on one of the interal HD. I have a G5 2.5
According to the Deja Vu wbsite the software is not compatible with Tiger at this time. Has anyone else been able to BU using Deja Vu and Tiger?
what is everyrone doing regarding BU and not being able to use Deja Vu?
Any drives I tried to back up while in tiger would not BU. But when I switched back to the drive with panther it would BU all Panther drives.
While in the tiger drive below is the message I get and the destination drive is empty it appears that it can;t recognize the destination drives
The following message is what I get.
Wed May 25 09:31:16 MST 2005 Deja Vu - Daily backup beginning
Started verify/repair permissions on disk disk0s3 Macintosh HD 1
Determining correct file permissions.
User differs on . private/var/at/jobs, should be 0, owner is 1
Owner and group corrected on .
private/var/at/jobs
Permissions corrected on . private/var/at/jobs
User differs on .
private/var/at/spool, should be 0, owner is 1
Owner and group corrected on . private/var/at/spool
The privileges have been verified or repaired on the selected volume
Verify/repair finished permissions on disk disk0s3 Macintosh HD 1
No entry found for ' Volumes/Lacie Ext HD Panther 3_1'.
Wed May 25 09:32:12 MST 2005 Deja Vu - Daily backup complete
tmp/dejavu_manual.rb:594: warning: $defout is obsolete; use $stdout instead
There is supposed to be a new version out. I updated mine pretty quick at home and it works like a charm. At work I use Synchronize Plus because DejaVu does not like my network drives.
After down loading the new vwesion 3.1 of Deja Vu should I move the old one to the trash and then install the new one and enter my code I got when I purchased the software.
there website is not too clear. It appears you have to download the software again for tiger and this is a trial version,of which one has to re-register and re-enter your code.
Am I coorect on this interpertation
Thank You
