Nikon D70 Focal Length: 19mm Optimize Image: Custom Color Mode: Mode IIIa (sRGB) Noise Reduction: OFF 2005/05/21 06:30:35.1 Exposure Mode: Aperture Priority White Balance: Auto -2 Tone Comp: User-Defined Custom Curve RAW (12-bit) Lossless Metering Mode: Multi-Pattern AF Mode: AF-S Hue Adjustment: 0° Image Size: Large (2000 x 3008) 1/40 sec - F/8 Flash Sync Mode: Not Attached Saturation: Normal Exposure Comp.: 0 EV Sharpening: Normal Lens: 12-24mm F/4 G Sensitivity: ISO 200 Image
Nikon D70 Focal Length: 20mm Optimize Image: Custom Color Mode: Mode IIIa (sRGB) Noise Reduction: OFF 2005/05/21 06:57:18.9 Exposure Mode: Aperture Priority White Balance: Auto -2 Tone Comp: User-Defined Custom Curve RAW (12-bit) Lossless Metering Mode: Multi-Pattern AF Mode: AF-S Hue Adjustment: 0° Image Size: Large (2000 x 3008) 1/8 sec - F/22 Flash Sync Mode: Not Attached Saturation: Normal Exposure Comp.: 0 EV Sharpening: Normal Lens: 12-24mm F/4 G Sensitivity: ISO 200 Image
Nikon D70 Focal Length: 14mm Optimize Image: Normal Color Mode: Mode Ia (sRGB) Noise Reduction: OFF 2005/05/21 07:44:40.8 Exposure Mode: Aperture Priority White Balance: Auto -2 Tone Comp: Auto RAW (12-bit) Lossless Metering Mode: Multi-Pattern AF Mode: AF-S Hue Adjustment: 0° Image Size: Large (2000 x 3008) 1/3 sec - F/22 Flash Sync Mode: Not Attached Saturation: Normal Exposure Comp.: 0 EV Sharpening: Auto Lens: 12-24mm F/4 G Sensitivity: ISO 200 Image
Nikon D70 Focal Length: 12mm Optimize Image: Normal Color Mode: Mode Ia (sRGB) Noise Reduction: OFF 2005/05/21 10:16:06.8 Exposure Mode: Aperture Priority White Balance: Auto -2 Tone Comp: Auto RAW (12-bit) Lossless Metering Mode: Multi-Pattern AF Mode: AF-S Hue Adjustment: 0° Image Size: Large (2000 x 3008) 1/8 sec - F/22 Flash Sync Mode: Not Attached Saturation: Normal Exposure Comp.: 0 EV Sharpening: Auto Lens: 12-24mm F/4 G Sensitivity: ISO 200 Image
Nikon D70 Focal Length: 12mm Optimize Image: Normal Color Mode: Mode Ia (sRGB) Noise Reduction: OFF 2005/05/21 07:56:10.1 Exposure Mode: Aperture Priority White Balance: Auto -2 Tone Comp: Auto RAW (12-bit) Lossless Metering Mode: Multi-Pattern AF Mode: AF-S Hue Adjustment: 0° Image Size: Large (2000 x 3008) 1/2.5 sec - F/22 Flash Sync Mode: Not Attached Saturation: Normal Exposure Comp.: -0.3 EV Sharpening: Auto Lens: 12-24mm F/4 G Sensitivity: ISO 200 Image
Nikon D70 Focal Length: 12mm Optimize Image: Normal Color Mode: Mode Ia (sRGB) Noise Reduction: OFF 2005/05/21 08:34:10.9 Exposure Mode: Aperture Priority White Balance: Auto -2 Tone Comp: Auto RAW (12-bit) Lossless Metering Mode: Multi-Pattern AF Mode: AF-S Hue Adjustment: 0° Image Size: Large (3008 x 2000) 1/13 sec - F/9 Flash Sync Mode: Not Attached Saturation: Normal Exposure Comp.: 0 EV Sharpening: Auto Lens: 12-24mm F/4 G Sensitivity: ISO 200 Image
Nikon D70 Focal Length: 105mm Optimize Image: Normal Color Mode: Mode Ia (sRGB) Noise Reduction: OFF 2005/05/21 11:37:01.9 Exposure Mode: Programmed Auto White Balance: Auto -2 Tone Comp: Auto RAW (12-bit) Lossless Metering Mode: Multi-Pattern AF Mode: AF-S Hue Adjustment: 0° Image Size: Large (3008 x 2000) 1/320 sec - F/4.5 Flash Sync Mode: Not Attached Saturation: Normal Exposure Comp.: 0 EV Sharpening: Auto Lens: 70-200mm F/2.8 D Sensitivity: ISO 200 Image
The rest of the pictures:
http://lenscapephoto.smugmug.com/gallery/548192/1/22743654
P.S. Originals are little less saturated (red) and brighter.
'you don't take a photograph, you make it.' - Ansel Adams
http://www.lenscapephotography.com
