The 50 mm can be used with Nikon's excellent close-up lenses, but
I doubt you will be satisfied when comparing the same image shot
with the 60mm micro.
The 60mm micro can be used as a portrait lens and will deliver
great results, except that the 50mm wider open will give better
back-ground seperation due to narrower depth of field.
For protraits I prefer the 85mm, f1.8 over the 50mm (f1.4 in my case).
Buying both the 85mm and the 60mm will set you back 7 times as much
as the 50mm, f1.8 plus a close-up lens.
FYI, my 60mm micro does not auto-focus well at close distances on
the D70. It just can't find a lock. Not sure why, so I always use
MF. This is generally not a problem with macro work anyway.
Phil
For make Macros and portraits??
Some feedback would be wonderfull!!
Thx 4 all the replys, yes i need good lens for low light
conditions, like a club or concerts shots, maybe the 50mm 1.8 be
the better choice then??
If i could reach very close to the stage and if not?? The 85mm 1.8??
For the macro the tamron 90mm 2.8 costs almost the double then the
Nikon 60mm and i don´t need to shot on shy insects cause isn´t a
kind of photos i like very much to do (even i like to see
wonderfull shots of that kind in this forum) the macro lens i need
is more for rings, coins, flowers etc, it worth the difference??
Seems that price differs very much on different locations. Here in sweden the Tamron is about 75% of the price of the 60mm Nikkor.For the macro the tamron 90mm 2.8 costs almost the double then the
Nikon 60mm
Well... Longer focal lenght gives both more working distance and better background control. More working distance give not only abillities for insects, but it's also easier to get the light to the subject. On the other hand the risk for camera shake is less with a shorter focal length.and i don´t need to shot on shy insects cause isn´t a
I think that would be a very good solution. This is what I'm thinking of for myself, when I get the money. The Sigma 70-200/2.8 might also be a good choice. It's faster focusing due to the HSM focusing motor.thinking in a Nikon 80-200 2.8 maybe with a TC 1.4 what do u think
of this??
For the soccer games the VR will not be THAT much of a help. You will need fast shutter speeds to freeze the action anyhow. It might help you be a little more steady while panning. A monopod might take care of that too though.amazing the 70-200 2.8 VR is, u think that with a little more of $$
i can be more happy with the 70-200 VR then 80-200 with a TC??
--After long time of doubts, the decision is made!
In about 15-20 days if all works well, i could have in my hands
(broken hands ehehehe) the
Nikkor 50mm 1.8 AF D
Nikkor 85mm 1.8 AF D
Nikkor 105mm 2.8 AF Micro
Nikkor 80 -200mm 2.8 ED AF
TC -14E II
It was a best choice??
