http://kkm.smugmug.com/gallery/383369/1/15288841
It is image# 4 of 12 in Animals.
Neil
Sorry but the picture you reply to dont show!
Like the d70.. but everything has its limitasions.
http://www.kkm.smugmug.com
Neil
[Image]
Make = NIKON CORPORATION
Model = NIKON D70
Orientation = top/left
X Resolution = 300
Y Resolution = 300
Resolution Unit = inch
Software = Ver.1.03
Date Time = 2005-01-15 12:40:03
White Point = [313/1000 329/1000]
Primary Chromaticities = [64/100 33/100 21/100 71/100 15/100 6/100]
YCbCr Coefficients = 299/1000 587/1000 114/1000
YCbCr Positioning = co-sited
Exif IFD Pointer = Offset: 340
[Camera]
Exposure Time = 1/160"
F Number = F4
Exposure Program = Aperture priority
Exif Version = 0221
Date Time Original = 2005-01-15 12:40:03
Date Time Digitized = 2005-01-15 12:40:03
Components Configuration = YCbCr
Compressed Bits Per Pixel = 1
Exposure Bias Value = 0EV
Max Aperture Value = F2.83
Metering Mode = Pattern
Light Source = Shade
Flash = Off
Focal Length = 200mm
Maker Note = 24850 Byte
User Comment = (c) Kjetil Kvien Madsen
Subsec Time = 0.70"
Subsec Time Original = 0.70"
Subsec Time Digitized = 0.70"
Flashpix Version = 0100
Color Space = Uncalibrated
Exif Image Width = 3008
Exif Image Height = 2000
Interoperability IFD Pointer = Offset: 25834
Sensing Method = One-chip color area sensor
File Source = DSC
Scene Type = A directly photographed image
CFA Pattern = [2,1],
[1,0]
Custom Rendered = Custom process
Exposure Mode = Auto exposure
White Balance = Manual white balance
Digital Zoom Ratio = 1x
Focal Length In 35mm Film = 300mm
Scene Capture Type = Normal
Gain Control = None
Contrast = Normal
Saturation = Normal
Sharpness = Soft
Subject Distance Range = unknown
Gamma = 2.2
[Interoperability]
Interoperability Index = R03
Interoperability Version = 0100
[Thumbnail]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 300
Y Resolution = 300
JPEG Interchange Format = Offset: 25972
JPEG Interchange Format Length = Length: 10679
[Maker Note]
Makernote Version = 0210
ISO Speed Used = 500
Quality = BASIC
White Balance = SHADE
Sharpening = MED.L
Focus Mode = AF-C
Flash Setting = NORMAL
Auto Flash Mode =
White Balance Bias Value = -3
000D = 00 01 06 00
Exposure Diff = 00 01 0C 00
ThumbOffset = 1430
Flash Compensation = FC 01 06 00
ISO Speed Requested = 500
Photo corner coordinates = 0 0 3008 2000
0017 = 00 01 06 00
Flash Bracket Compensation Applied = 00 01 06 00
AE Bracket Compensation Applied = 0EV
Tone Compensation (Contrast) = CS
Lens Type = Nikon G series Lens
Lens Min/Max Focal Length, Max Aperture = 700/10 2000/10 28/10 28/10
Flash Used = Flash Not Used
Auto Focus Area = 02 02 00 00
