Taking Photos from Moving Train?
  • Thread starter Thread starter Beth
  • Start date Start date
Beth wrote:
We leave next week to go cross-country on the Amtrak. Anyone have
tips on taking good photos from a moving train? Or how to get good
shots of people inside of a moving train?
I'm fairly new to digital photography but took some shots out of a moving train during our recent vacation. Fortunately I there were no windows so I didn't have to worry about glare.
If I were you, though, I'd take a 35 mm film camera with a good polarizing filter. That way you can adjust it to minimize if not totally eliminate window glare when taking shots from outside in. You can also vary shutter speed for various photo effects of moving scenery. If you have a 35 mm camera you may wish to post a similar question in a SLR forum. I'm sure there are many experienced photographers there who can give you worthwhile tips.
gail
Beth,
The wife and I recently took the Amtrak from Ventura to Oceanside.
The one thing you'll need to do is clean the window from the outside.
They are generally very dirty. I got alot of weird looks when I was cleaning it at one of the stops along the way.
This is also only going to work if you are on the lower level and can physically get to the window.
Jim C.
Olympus C3000Z
Gallery: http://www.pbase.com/galleries/cokids
Ok, here are my tips to add to those you already have.
1. Remember the train is moving. So try not to include anything in the foreground that is very close to the train or it will show movement blur. That is fine, if you want movement blur, which you should have in at least some of your shots so you can say, "Hey, I was on a train." Try using a slower shutter speed, like 1/60 or 1/30th on a shot or two. Shoot at a 90 degree angle from the train using a wide angle. You should be able to show a lot of movement blur in the foreground and much less or none in the distance. Sort of cool shot if you can pull it off.
2. Remember the train is moving! Try to shoot some of the shots at less than a 90 degree angle from the train. That should reduce the motion blur.
3. Remember the train is VIBRATING, so don't press you camera up to the glass of the window. Get it close, but don't touch it.
4. Use a hood or a jacket to cut down on reflections off the glass. wrap it around the camera and push it against the glass out of the field of view. That will eliminate all glare. Next best bet is the polarizer, but that will reduce your shutter speed or f-stop and is moving you in the wrong direction.
5. For shooting inside the train, you can use flash, but remember to use a mode that allows you to see out the windows. In other words, shoot will a fill flash at a higher OSI and a wide f-stop. That way you can see inside and outside of the train, in the same shot.
6. Use both a wide angle and telephoto inside the train. Use the telephoto to compress the compartment down the isle, that will look cool.
7. Don't forget to take some natural light shots inside the train of people sitting next to windows. Very classic shot, don't want to miss that.
8. Don't leave your camera sitting around, it will walk off.
I have seen pictures taken from a moving train that were all out of focus. It is my best guess that the lens autofocus was set to automatic and focused on the window or maybe even dirt on the window. You might consider using manual focus and setting your lens to infinity.
