British Fuji brochure for S1
Stanford Shaw
New member
Los Angeles, CA, US
FUJI PHOTO FILM CO., LTD.
26- 30, NISHIAZABU 2- CHOME, MINATO- KU, TOKYO 106-8620, JAPAN
All trademarks are the property of their respective holders.
DIGITAL CAMERA FinePix S1 PRO
• Histogram display shows exposure results immediately after a shot.
• Separate controls are available for color temperature, gradation and sharpness settings.
• Color and grayscale display allows you to check the color or highlight/shadow reproduction.
• Dual slots are installed for storing images on both SmartMedia™ and CompactFlash™ Cards,
including the IBM Microdrive™.
• The USB cable and software allow for transferring images stored on the memory card to the PC and
enable you to send instructions to the FinePix S1 Pro for control and shooting.
• The camera is powered by four AA alkaline, Ni-MH or Ni-Cd batteries which are readily available.
Specifications are subject to change without notice.
Type of camera Interchangeable-lens SLR-type digital camera
CCD sensor 23.3 ´ 15.6 mm Super CCD
Image file size 6.1 million pixels (3,040 ´ 2,016) 2,304 ´ 1,536 pixels
1,440 ´ 960 pixels
Sensitivity Equivalent to ISO 1,600 maximum
File format TIFF-RGB, TIFF-YC, JPEG (supports Exif Ver. 2.1)
  • Design rule for Camera File system-compliant/DPOF-compatible
Storage media Slot No. 1: SmartMedia™ Card (3.3V, 2 MB to 64 MB)
Slot No. 2: CompactFlash™ Card type II
Number of images Mode TIFF-RGB TIFF-YC JPEG (Fine) JPEG (Normal) JPEG (Basic)
(3,040 ´ 2,016 pixels) MG-64S 3 5 26 53 101
Lens mount Nikon F mount
Usable lenses AF Nikkor and AI-P-type Nikkor lenses (IX-Nikkors
cannot be used)
Picture angle Approx. 1.5´ focal length in 35 mm [135] format equivalent
Viewfinder Fixed-eye level penta-prism high-eye-point type
Frame coverage: Approx. 90%
Shooting modes Single frame shooting
Continuous shooting: approx. 1.5 frames/sec. up to 5 frames
Preview mode
Multiple exposure
Exposure modes General-Purpose Program
Auto-Multi Program (Flexible Program possible)
Shutter-priority Auto mode
Aperture-priority Auto mode
Manual Exposure Control mode
5 Vari-Program mode
Exposure 1. 3D Matrix: with D-type AF Nikkor
metering 2. 6 segment Matrix: with non D-type AF Nikkor or AI-P-Nikkor
lenses
3. Center-weighed: in Manual Exposure mode or with
Auto Exposure Lock
Exposure ±3 EV range, in 1/3 EV increments
compensation
Autofocus detection TTL phase detection
system Detection range: EV-1 to EV 19 (ISO 100 equivalent, at
normal temperature)
White balance Auto/Fine/Shade(fine weather) Incandescent light
3 modes for fluorescent light/Custom setting
Shutter Electronically controlled vertical-travel focal-plane
shutter
Shutter speed 30 to 1/2,000 sec.
Remote release Mechanical remote terminal
Built-in flash Guide No.15 (ISO 100 • m), effective for 28 mm lens
frame coverage)
TTL-BL flash operations: Normal/slow-synchro/red-eye
reduction/red-eye reduction with slow-synchro
Accessory shoe Standard ISO-type with hot-shoe contact, ready-light
contact, TTL flash contact, monitor contact; mount
receptacle for Posi-Mount system provided
Playback 1) 1 frame 2) Thumbnails in 4 segments 3) Thumbnails in
functions 9 segments 4) Playback zoom 5) Histogram indication
6) Standard chart
LCD monitor 2-inch low-temperature polysilicon TFT (approx. 200,000
pixels)
Self timer 2 sec. (quick mode) and 10 sec.
Video output NTSC (USA/Canada model) or PAL (European model)
Digital interface USB
Power source 1. 4 AA batteries: Alkaline, Ni-MH or Ni-Cd
batteries can be used (manganese batteries cannot be
used) or AC power adapter for image-handling
system
2. 2 Lithium batteries (Type CR123A) for controlling
camera system
Dimensions 148.5 (W) ´ 125 (H) ´ 79.5 (D) mm/
5.8 (W) ´ 4.9 (H) ´ 3.1 (D) in.
Weight Approx. 820g/29 oz. (without batteries and lens)
Ref. No. EB-003E (SK·00·01·DT·MW) Printed in Japan © 2000 Fuji Photo Film Co., Ltd.
Please see my question just posted on the Nikon Talk Forum and respond if you can. Thanks.
sharpness settings.
shooting.
1,440 ´ 960 pixels
(Basic)
cannot be used)
Preview mode
Multiple exposure
5 Vari-Program mode
lenses
Auto Exposure Lock
compensation
normal temperature)
shutter
frame coverage)
6) Standard chart
pixels)
system
camera system
Co., Ltd.
