MichaelT
Dan,Just upgraded it and it runs and displays a dialog box say can set
focus to list, abort, retry, ignore....
All trashed my log in and erased all bookmarks, wallpaper, etc.
Is this a known fault?
D.
First of all I am sorry that you had the problem. That is why it is labeled a Release candidate. There is a potential for problems, like with all new releases. I am just being honest about the state of the release. Despite losts of testing there can always be some hidden buigs that do not get uncovered until the SW is out in the field.
First a gripe from me to you...To Post with a subject line of...
"It doesn't run on XP"
Does not serve you, me or the forum. It leaves a bad impression for Yarcplus when in fact it is not true. making that statement based on the data that you had would be like having your car break down in Nevada and making the statement that "my car won;t run in Nevada." There are a few variables here, so let's get back to reality. End of gripe.
Many of our external testers run XP and I also test sometimes on XP. So the problem is not XP. Over.
Now to what IS the problem. As noted in the post on our message board there was a bug that may or may not have caused your problem. I have posted a new version (V2.0 RC1) that fixes that bug so people do not have to deal with it.
You say you are a programmer, so please work with me and not against me. I need to know the full details of the first error message that you get and the conditions under which you get it. A screen shot is fine, or just the words.
Then perhaps we can find out what the problem is. So I suggest the following.
Uninstall V2.0 RC
Install V2.0 Rc1
Run YarcPlus report back to me (better on the YP forum than waste the peoples time here and also I get an email from the forum when you post so I can answer more timely than scanning here.
if you get an error, please send me the screen shot.
The only thing that comes to mind is that on some XP systems OCX files do not register properly. So if you get an error please register the following files in the YarcPlus folder.
Histoview.ocx
Thumbview.ocx
PicView.ocx
ccrpbds6.dll
Since you are a programmer I assume that you konw hoe to register these files. if not let me know.
Then try to run YP again.
Like I said we have many XP users, so there is something special goingon here. If we work together we can figure it out.
Reagrding the other problems you had with your system, It is very unlikely that YP had anything to so with that. Of course anything is possible, but we do not go near anything that would cause such an issue.
Non the less, I regret the problems that you had.
I look forward to hearing from you.
Please respond to the YP forum or to me on email.
Michael Tapes
http://www.YarcPlus.com
http://www.michaeltapes.com
