I seems better and easier to have the grip, controls and EVF rotate 90 degrees and have the internals of the camera fixed. But in either way is a complicated design change for solving a small issue.Would it be technically too hard to have a rotating sensor in a small body instead of a gripped body?
Why it is so hard to rotate the camera with your hands? I would think having one less moving part is saving a lot of chance for another moving part to fail.Would it be technically too hard to have a rotating sensor in a small body instead of a gripped body?
If it were that obvious, in practical terms not just as an idea, it would have been done already.It's an obvious improvement. All the control buttons don't move. The hand positions and tripod config doesn't change either. The screen and EVF would need to be square and letterboxed which would affect the camera design.Instead of rotating why not square then?
Would the raw be a square, with a defaulted outline location embedded? A big file though. (Raws now are slightly larger than the jpg. In the edit, corrections need to be turned off to show the full size.)
I have a better idea. Why not flip the sensor at the beginning of the exposure and then flip it back facing away from the lens? This would eliminate the shutter!Would it be technically too hard to have a rotating sensor in a small body instead of a gripped body?
I think it's a dealbreaker for just about everyone.This seems like a deal breaker to me. Almost all my lenses have a rectangular rear baffle/plate/opening, and many (but not all) have petal hoods. This also leans against the idea of a square sensor.
- Image quality. High end lenses are "cropped rectangular" by their petal lens hoods (which are built-in on some lenses like ultrawides or fisheyes) or internal baffles
Because most movement is horizontal. When you have a vertical scan the "image sheer" leads to moving objects "leaning into" motion, while a horizontal scan either compresses or elongates objects, a much more unpleasant effect. That "lean into motion" effect was part of sports photography for decades, even in theI've not heard of the scanning orientation mattering that much. I'm curious— why?
- Redesign of the sensor for multidirectional scanning and cropping. Right now they scan top to bottom, which is great for landscape but horrible for the vertical orientation (this is also a problem when you rotate your camera).
Hasselblad does it on one of their cameras. Very clunky.Would it be technically too hard to have a rotating sensor in a small body instead of a gripped body?
What Hasselblad does that ?Hasselblad does it on one of their cameras. Very clunky.Would it be technically too hard to have a rotating sensor in a small body instead of a gripped body?
It would be better to use square sensors. And cheaper. The cameras would get a bit larger, though. That's not the worst idea, however, extracting three most out of the lenses.
As far as I know, only three Hasselblads had that feature:What Hasselblad does that ?Hasselblad does it on one of their cameras. Very clunky.Would it be technically too hard to have a rotating sensor in a small body instead of a gripped body?
Just rotate the lens mount with the sensor!This seems like a deal breaker to me. Almost all my lenses have a rectangular rear baffle/plate/opening, and many (but not all) have petal hoods. This also leans against the idea of a square sensor.
Yes, it's just so easy.Just rotate the lens mount with the sensor!This seems like a deal breaker to me. Almost all my lenses have a rectangular rear baffle/plate/opening, and many (but not all) have petal hoods. This also leans against the idea of a square sensor.
Exactly! That’s the secret trick.Yes, it's just so easy.Just rotate the lens mount with the sensor!This seems like a deal breaker to me. Almost all my lenses have a rectangular rear baffle/plate/opening, and many (but not all) have petal hoods. This also leans against the idea of a square sensor.
In fact most things are really easy to do in theory.
Yes, those little killjoys.Things change when the practice bit comes into play. it's always those little details that spoil the fun.
Because we need to leave something for the photographer to do.Would it be technically too hard to have a rotating sensor in a small body instead of a gripped body?
