Alexander Meredith
Leading Member
Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
1) Panasonic is protecting their "high-end" cameras. This is a bad idea, and is normally saved for companies that can absolutely afford to do this (ie: Canon). Why buy a GX8 when you can get a better camera in the G80 if it had the 20MP sensor? That is likely Panasonic's thinking.Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
The 20mp sensor costs significantly more. Part cost is looked at closely when making design decisions in a consumer electronics company.1) Panasonic is protecting their "high-end" cameras. This is a bad idea, and is normally saved for companies that can absolutely afford to do this (ie: Canon). Why buy a GX8 when you can get a better camera in the G80 if it had the 20MP sensor? That is likely Panasonic's thinking.Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
Pany makes their own 16mp sensors, so in theory they will never run out ;-) ... (It's not the same group inside Pany that makes the cameras, but there is obviously some pressure to use their home grown sensor tech.)2) Clear out their inventory of 16MP sensors. They may have done a large bulk buy on those sensors and still need to flush them out. Again, not a good strategy for smaller camera companies trying to solidify a decent position in this shrinking market. Smaller camera companies have to show clear value over the competition. Its the only reason Pentax still exists.
I'm just not sure this is true. Sure, it probably costs more, but it can't cost significantly more or else the YI M1 would be much more expensive. And they are buying direct from Sony in likely not very large quantities (since they only have one camera atm).The 20mp sensor costs significantly more. Part cost is looked at closely when making design decisions in a consumer electronics company.1) Panasonic is protecting their "high-end" cameras. This is a bad idea, and is normally saved for companies that can absolutely afford to do this (ie: Canon). Why buy a GX8 when you can get a better camera in the G80 if it had the 20MP sensor? That is likely Panasonic's thinking.Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
I really like reason number 1!!! Some have said stabilizing a 20MP sensor is much more difficult than a 16 MP sensor. If that is true it may be a consideration but I think answer 1 is the real reason. I do mostly landscape work now so the more MPs the better. I also use the horrible old 4/3 lenses for this work. With Olympus withholding the price of the EM1ii I have been considering the GX8 again looking at the features I really need for landscape shooting and the fact the EM1ii may be double the price or more.1) Panasonic is protecting their "high-end" cameras. This is a bad idea, and is normally saved for companies that can absolutely afford to do this (ie: Canon). Why buy a GX8 when you can get a better camera in the G80 if it had the 20MP sensor? That is likely Panasonic's thinking.Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
Panasonic Semiconductor can probably sell 16MP chips to Panasonic Camera much more cheaply than Sony Semiconductor can sell 20MP chips to Panasonic Camera. Doesn't mean Panasonic Semi will sell the 16MP chip more cheaply outside the company, though. Family discount.I'm just not sure this is true. Sure, it probably costs more, but it can't cost significantly more or else the YI M1 would be much more expensive. And they are buying direct from Sony in likely not very large quantities (since they only have one camera atm).The 20mp sensor costs significantly more. Part cost is looked at closely when making design decisions in a consumer electronics company.1) Panasonic is protecting their "high-end" cameras. This is a bad idea, and is normally saved for companies that can absolutely afford to do this (ie: Canon). Why buy a GX8 when you can get a better camera in the G80 if it had the 20MP sensor? That is likely Panasonic's thinking.Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
Exactly! When you're in manufacturing, saving $3 in part cost on an item that retails for $1000 may sound like nothing, but $3 would be considered to be a considerable cost savings.Let's not forget that Panasonic's camera division probably isn't the most profitable division in the conglomerate - if they can save $3/camera, they'll probably consider saving $3/camera.
Just charge $3 more dollars? Yes, the cost is likely more than that (probably on the order of $20-$30 more for the 20MP sensor), but it clearly would not make a bit of difference to the buyer who is already shelling out $800+. Charge another $20 or 30 and give them the 20MP sensor.Exactly! When you're in manufacturing, saving $3 in part cost on an item that retails for $1000 may sound like nothing, but $3 would be considered to be a considerable cost savings.Let's not forget that Panasonic's camera division probably isn't the most profitable division in the conglomerate - if they can save $3/camera, they'll probably consider saving $3/camera.
My guesses:Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
GX8 is not a sensor. So a body sale does not show anything at all related to the sensor.My guesses:Just wondered why the new G80/85 and GX80/85 are still using the 16Mpx sensor albeit with no anti-aliasing filter.
- Sales of GX8 showed Panasonic that 20Mp vs 16MP is not a big deal for most buyers.
Again no: a few years is enough to address this easily with faster processers and faster sensorreadout. 16-20 MP is nothing compared to 2 to 3 times the processing speed.- 16MP allows faster performance, better IBIS, lower cost, whatever... things that are a big deal for most buyers.
GH5 does not get you 6 K video. It gets you 6K photomode. But yes: from the look of it not only does it need more than 16 Mp, it needs well over 20 MP too.- GH5 needs more than 16MP to deliver 6K video.
