n3eg
Never really knew a right or wrong, just that my Pentax Auto 110 had the release on the same side. Good thing internet forums weren't around then, or I might have been led into thinking it was wrong.
This is indeed a key factor- cameras are generally designed for two handed operation, not one.Guy Parsons wrote:
It is really designed to be held by both hands.... the left hand usually supporting lens plus left end.Abrak wrote:
Ok I know that many people will think they are on the 'right' side but please bear with me. Pick up your camera - it is designed to be held 'one-handed' by the 'right' hand. There is far more space on that side of the camera and probably a grip.
I have a slightly different grip- I tend to hold the back of the camera in the palm of my hand, which (on m4/3 bodies) still gives me enough reach to hold the release button with index or middle finger. That said, I have long fingers, so that grip may not work for everyone.The left hand clutches the left side of the camera (in a firm hold), just moving around from the usual left hand lens/body support function, and a finger squeezes the release button...So how do you change lenses?
Hmm, yeah it does seem like the stupid side to be on and if you use a Leica camera, where the lens release is on the right hand side of the lens, so that you can maintain your grip on the lens with your left hand and use the middle finger of your right hand to release the lens it is a great joy and ergonomically superior.Abrak wrote:
Now look at the lens release. It is on the opposite side of the camera. You can only press it with your left hand. And if one hand is holding the camera and one hand is pressing the lens release then you are short of a hand to take out the lens.
So how do you change lenses? Well I tend to rather precariously hold the camera on the short side with my left hand so I can press the release with the left hand also and use my right hand to take off the lens.
I do realize that it is traditional to have the lens release on the 'wrong' side. However I cant help being envious of a couple of manufacturers - Nex and Fuji - who have decided to put their lens release on the right side.
I'm for going back to the OM Zuiko way with the lens release button on the lens. That was far easier, far quicker, and far safer.george4908 wrote:
Yup. With OMs, it's a faster, one-step operation. Less fiddly. I'm surprised they didn't carry this forward to the OM-D, but maybe the 4/3 consortium ruled otherwise.hindesite wrote:
(Not OM-D).
Lens release is on the lens body. You squeeze the release as you hold the lens to remove it. Doesn't matter which hand you use.
It falls naturally to the left hand to both hold the camera and press the button.Now look at the lens release. It is on the opposite side of the camera. You can only press it with your left hand. And if one hand is holding the camera and one hand is pressing the lens release then you are short of a hand to take out the lens.
The left hand clutches the left side of the camera (in a firm hold), just moving around from the usual left hand lens/body support function, and a finger squeezes the release button. Then the right hand twists off the lens, plonks it in the vacant compartment in the bag, swap rear caps, lift and twist in the fresh lens WITHOUT holding the release button. Ready to shoot again.So how do you change lenses?
Had to swap a lens just now to see how I do it, never think, just happens.
The left release button works fine for me as the more dextrous right hand is doing the lens handling performance. I do use a wrist strap so for all that swap time the right hand/wrist is threaded through the wrist strap so no risk of camera dropping to the ground.Well I tend to rather precariously hold the camera on the short side with my left hand so I can press the release with the left hand also and use my right hand to take off the lens.
Never have dropped a lens or a camera in 60 years of lens changing.
Regards...... Guy
Not many of us want Leicas....plevyadophy wrote:
Wow!!
That sounds horribly complicated compared to the ease with which one changes lenses on a Leica camera.............. because the lens release button is on the right hand side of the lens mount (so activated by right hand).
I only used Leica as an example, not saying peeps should rush out and buy, LOL! Unless of course they are buying one for meGuy Parsons wrote:
Wow!!
The write-up of how to change my lens was tortuous because I had to grab my bag and go through the motions to see what I actually do. It's all easy and smooth and quick and mostly done without thinking (like most things in my life).
Easier using the small 3 compartment shoulder bag, a bit slower and more juggly if using the small snoot bag where the spare lens lives under a flap.As mentioned, the proper length wrist strap makes it so easy.
After years of Nikon the M4/3 was quite natural, except that the lens twists the wrong way.
Anyhoo, I'm looking forward to getting a second E-PL5 body next post Christmas discount season here in Oz and that will lessen the need to change lenses anyway. Mainly buying that for backup reasons after a sad experience with my second E-PL1. Two bodies and three lenses makes a nice to carry and use outfit.
Regards....... Guy
Art_P wrote:
I'm in the 'hold camera w left hand, twist lens w right' camp, but it's not the only way to change lenses.
Try this: Holding the camera in right hand and new lens tucked in right arm. Now grasp the barrel of the mounted lens from the top w left hand, thumb over the release button. press button and twist lens, remove. tuck this lens next to other lens and swap back cap. Grab the new lens, insert and twist, then place other lens in pocket.
Actually, this is more like changing an OM lens, as w that mount the release is on the barrel of the lens, not the body.
Consider this: if the release was on the other side, it would increase the chance of accidentally pressing it while shooting.
Clever but flawed.Pekuliar wrote:
I found that this technique works very well with MFT-cameras, you just have to tweak your left hand grip a bit. It makes switching lenses really quick and keeps sensor exposing to a minimum.
And here's another lens change video, and in it the presenter criticizes that fancy technique shown in the link above.plevyadophy wrote:
With mFT lenses I can see this as being a great way of overcoming an ergonomically flawed system (and without doubt, a left hand side lens release button is flawed in comparison to the smooth ergonomics of a right hand side release button).
Even the dude in the video, who obviously is practiced at that technique he demonstrated, is fumbling somewhat. That seems to me to be a recipe for dropping lenses; however, with the small lenses of the mFT system this will be less of an issue.
For large mFT lenses or for changing lenses on a large body like say a Canon 1D the technique demonstrated in the video is not really of much use.
I am with the OP (original poster) on this, I believe that left hand release buttons are obviously ergonomically flawed (and if it is not obvious to anyone then I suggest, for a while, they go use a camera with a right handed release and it will become quickly apparent). However, given that we are lumbered with these left hand buttons, we just have to come up with ways of minimising the poor ergonomics and I think the video link you have posted is not a bad start, not great but it's a start.
Thanks for the link.
plevyadophy
Does Leica's customers have a problem with the lens release button being on the right hand side?Mike_PEAT wrote:
nt=No text
Since you only need to depress the button for a few mm of the turn you can remove lens using your left hand:plevyadophy wrote:
Wow!!
Regards....... Guy
I think on small bodies like the mFT cams it's a little less noticeable how ergonomically unfriendly it is to have the lens mount button to your left. But if you ever use say, manual focus lenses with an adapter that has the manual focus lens release to your right hand side, you will see the far superior ergonomics of release the lens with your right index or middle finger as compared with the left handed release of the native mFT lenses.
The clumsiness of left handed release is more obvious on full sized DSLR cams.
Right handed release is by FAR a superior way to remove a lens but as I said in a previous post in this thread ..... there may be manufacturer concerns and user benefits
That's exactly how I do it ............ with lighter lenses and it works fine with many of the mFT lenses (which are light and tiny) but it doesn't get away from the fact that it is not the best way to do it ergonomically and that as the camera body gets larger and/or heavier and the accompanying lenses get bigger and heavier too this technique that you recommend (and which I use) shows its flaws.Lukas0101 wrote:
Wow!!
Regards....... Guy
Hold your camera with your right hand by the grip. Using left thumb press lens release button and start turning the lens at the same time with your left hand.
Even with the lens release on the left side, don't know how many times over the existence of 4/3 and m4/3 cameras I've read of people accidentally touching the lens release button while using the camera in normal use. Pressing the lens release button disables the electronics of the lens rendering it useless.plevyadophy wrote:
Do you reckon that there have been numerous cases of their insanely expensive lenses disconnecting whilst shooting?
