Excellent work, Emil! Comments as follows:
What I would like to see is something provided to
Phil
Since when is Phil given to admitting error?
Ah so ;-)
Unfortunately, I don't have a G10 or G9, and Imaging-Resource is not
hosting RAW test files of the G9. So I did the next best thing, I
compared two ISO 1600 images from the 40D and 50D, using the
following two RAW files:
Good choice, as this was also a review where DPR reviewer commented on "too many MP".
And indeed, performing this rescaling the noise performance of both
cameras' noise spectra are nearly identical! In fact, the properly
rescaled 50D data lies slightly below the 40D noise, because the 50D
is in fact slightly more efficient per unit area in capturing
photons, and so has a slightly higher S/N per unit area.
Does re-sampling in this way actually properly handle the frequencies that would be above the Nyquist frequency of the new re-sampledimage? If not, a slight blur filter prior to down-scaling would make the results of the 50D even better.
Also, it should be pointed out that the true demosiaced resolution of a Bayer sensor is quite a bit less than the pixel count says, where as the down scaled image likely has a higher resolution compared to the total pixel count. Again, compensating for these differences would make the 50D come out even better.
Finally, concerning this test, it worked so well as compared to theory because Canon DPP does not do much frequency "spreading" filtering when NR is turned off (as I understand). The results may not have been so close to theory using ACR which tends to spread the pixels even with all noise reduction sliders set to zero. This, of course is understood in the light that ACR has already cut the power of the highest frequencies.
Same comments for the re-sizing as for the re-sampling.
The takeaway lesson is that two cameras, one with 50% more pixels in
the same size sensor, have equal levels of noise when properly
compared, either by theoretically scaling the result of a raw
conversion, or by downsampling the higher resolution image to match
the lower resolution image.
Note that one doesn't have to theoretically scale the raw conversion as one could actually come up with an adaptation of these algorithms to re-scale or down-sample the raw data before raw conversion, in which case I suspect the results would be even closer to ideal.
If noise reduction had been performed, either in the RAW converter or
after conversion, the noise power at the highest spatial frequencies
would have been reduced. But since one can generate the noise
spectrum of the lower resolution sensor by downsampling before noise
reduction, whatever noise scrubbing one wishes to perform can be
made to have the same effect on both the 40D and the downsampled 50D
(though I wouldn't recommend it as an optimal post-processing scheme
for the 50D).
Yes, Noise Reduction (NR) is the bane of digital cameras, or especially noise reduction that reduces the resolution of the camera beyond it's best Bayer resolution.
It's interesting to note how NR has progressed with problems with cameras to suit reviews such as the ones on this site that compare noise by using the standard deviation method. The history was as follows:
1) There was no NR applied to JPEG's prior to the 5 MP 1/1.8" sensor models, which in some/most implementations had quite high noisie for ISO's of 400. the best of breed for high ISO use was the Canon S30 3 MP camera which could produce almost usable ISO 800 images.
2) One can observe across all the review done across the years on this website that non-NR'ed images have excellent image quality with a standard deviation of noise in the shadows of about 1.5 JPEG levels, adequate quality at about 3 JPEG levels, and barely acceptable quality at 5 or 6 JPEG levels.
3) Starting with some follow-up models using the 5 MP and higher sensors, NR was introduced to try to keep the higher ISO sensitivies noise standard deviations at about 3 JPEG levels in the shadows and no higher than about 5. In this way, higher and higher ISO's were offered by compact cameras in spite of the pixel density increase, although as you have pointed out, technology also improved.
4) Now with very much higher photosite densities that have brought us almost 15 MP in the best compact cameras, we can still produce adequate images at ISO 200, somewhat acceptable ones at ISO 400, and almost acceptable ones at ISO 800
at full resolution , with the main complaints at these higher ISO's being that detail is smeared.
I ask the retorical question, why bother with NR which just serves to throw away detail and give objectionable splotches when the camera may as well just produce successively greater reduction of the size of images with increasing ISO sensitivity? If it did this, we would still have very high resolution images at lowest ISO's and still have something like 4 MP or more at usable ISO's of about 800, which is better than we ever had in the past. As you can see, I am completely anti NR and pro
proper down-scaling.
And that, dear OP, is the purpose of pixel peeping as applied to improving over all image quality.
Regards, GordonBGood
