It depends on the image, of course. But in this case I used selective color adjustments. Didn't get as much from that as I wanted, so I added a blank layer in soft light mode and painted one swipe across the trees with a medium green, and two swipes with black across the top of the sky (large soft brush at 20% opacity) to deepen the blue. Finally, I duped the image, changed blend mode to soft light, and reduce opacity to 30%.
While the chapter summaries make easy reading, I highly recommend the book. Since the Dan Margulis book is probably the only book on the topic, selection is easy.
I have read some pages and chapters several times to try and understand was he's doing.
Essentially, the process is as follows:
Increase green/magenta contrast ("a" channel).
Increase blue/yellow contrast ("b" channel).
Steepen the critical area for bettwer contrast ("L" channel).
Adjust Shadows/Highlights("L" channel).
Apply USM ("L" channel).
I have also learned some semi-related topic such as channel masking reading portions of the book.
It takes a while to get a grip on the topic and get rid of the headache, but I now actually think in LAB.
i guess it's kind of like getting better in a foreign language. You know you're making progrees when you begin to think in that language.
To find the spot where you want to apply the steepest part of the "S" curve - open curves and slide the cursor around the most significant part of the actual photo. Hopefully you'll see a reather small part of the curve with a circle there (I think it's a circle). Make that the steepest part of the curve.
Just tried the painting with light using several different colors and adjusted shadows and highlights to get some of the mountain detail back. I realize this is a different image than the one you used but do you think I over did it or on the right track?
Used a workflow I picked up around here at some point that often gives interesting results with water:
-- Layer via copy
-- Desaturate
-- Invert
-- Set mode to overlay
-- Gaussian Blur - Radius, 80
