Karl Gnter Wnsch
I have presented them but you chose to ignore them, so bet it. Be happy with your crudge...Game, set, match. Please do indicate if you have arguments at a
later time.
regards
Karl Günter Wünsch
later time.
Right. Or math skills and intelligence, or research skills and intelligence, or analytical skills and intelligence, or reading skills and intelligence, or vocabulary level and intelligence, or....Further, only the most naive fools
assume a correlation between writing skills and intelligence.
If IS fails I can continue to shoot without it (I rarely use it anyway and serious photographers often don't need it either).We all know that many serious photographers have more than one
camera body, often even the same model, but how many photographers
have two 600 mm IS f:4 lenses "just in case the IS malfunctions".
Well a Pro without a backup camera isn't bearable, but if AS fails chances are the camera needs to go for an immediate repair whereas a defective IS is just a niggle that can be mended on the next lens revision anyway.With Minolta's system you can have some degree of security for the
price of a 5D, should the AS on your 7D die on you. Did you mention
something about prices somewhere?
So what you're saying is that the IDEA of it bothers you because it strikes you as counter-intuitive?Am I the only person who does not think that this is a good idea,
in fact it scares me in someways. In no way would we want a frame
of film to be moving in the body to help capture a sharper image,
so why allow the image sensor to move.
Surely trying to get the light to focus accurately on a static
object, such as a non moving sensor is a tough enough job but
trying to get the light to focus on a moving object will be even
harder to get right.
Minolta has stated that their in-body IS works with ALL lenses save for ONE of their macro lenses (I forget the reason why). No KM user has so far reported that AS has failed to work with any particular lens.Yes, I think this could be a problem. I wouldn't be surprised ifHowever, I'm not sure if this one size fits all thingy from Minolta
really works with all lenses to 100% ..
they implement a mechanism for IS not to work with certain lenses.
If you are serious about your photography you want to avoid blur, even blur caused by camera/lens movement, or am I terribly wrong about that?If IS fails I can continue to shoot without it (I rarely use itWe all know that many serious photographers have more than one
You seem to think that if AS doesn't work, the rest of the camera won't work, but I fail to see why. All the more so since you claim that an IS lens will continue to work. What if the IS element is jammed while not being centered?Well a Pro without a backup camera isn't bearable, but if AS failsWith Minolta's system you can have some degree of security for the
revision anyway.
AS and IS can to some extent replace a tripod, saving weight and in other ways making life easier for the photographer in the process, so if you need a tripod, sometimes you can just use AS or IS. Is that really so terrible?What you all seem to forget is that better pictures are made from
sturdy tripods, monopods or hand held without the need for any
image stabilisation because the criteria for using this technical
aid aren't met. So why have AS on when you are shooting at
1/1000th? Or at 1/20th from a tripod, on that shutter speed I need
mirror lockup but no AS.
IMO "serious" photographers are the ones most likely able to afford the high cost of IS lenses. My guess would be that a very high percentage of IS sales are to pro photographers.If IS fails I can continue to shoot without it (I rarely use itWe all know that many serious photographers have more than one
You raise a valid point regarding added complexity, though. I have heard of at least one KM 7D that wouldn't operate at all due to an AS problem. OTOH, I have heard of one where AS was broken but could still function as a non-AS camera.Well a Pro without a backup camera isn't bearable, but if AS fails
revision anyway.
One could also argue that "better" pictures are made with large format or medium format cameras on huge tripods. The point is that, just like with 20D-sized cameras and its APS-sized sensor, we make decisions based on convenience, cost and performance. Using IS is a choice for the convenience of not having to use a tripod in some situations.What you all seem to forget is that better pictures are made from
That's an old hat already: Contax AX did years ago - even AF!Interestingly, if you can move the sensor, then you could also
focus the lens in camera...
I have not read every response to this message but can anybody really CONFIRM that the technology of in-body IS is due to sensor movement ?Am I the only person who does not think that this is a good idea,
We are talking about holding a 100mm at 1/15s. And getting a decent proportion at 1/8s.in the hope that one out of the 2 or 3 will be sharp.Guillaume paris2 wrote:
Uhm, doesn't a professional get hired because he knows that his
pictures are sharp, not because he hopes?
If I couldn't shoot with a 70mm handheld at 1/45, then I would
practice a bit on my technique instead of praying for (IMHO)
useless clutches
1. I assume you meant CRUTCHES not CLUTCHES.
2. A good professional takes multiple shots because he knows that
the unexpected can happen, such as the subject blinking. He does
not get hired with the assumption that every shot will be perfect.
Why do you think so many professionals want good multishot
capability in the camera body?
3. Shooting at shutter speeds slower than 1/focul length is always
a risk, and many wouldn't shoot that slow. In the "good old days"
photographers used huge flash units that gave more even light, and
even then may have taken a dozen shots to get the one classic shot
that you're thinking about. There were many events that were never
recorded because flash photography wasn't allowed and film/camera
technology couldn't handle the situation without a flash.
4. And finally, by traditional standards, autofocus and even
in-camera metering could be considered crutches. It took many years
for autofocus to be taken seriously, but now it is a standard tool
for 35mm photographers. IS is the same way - it is a great tool
that makes it possible to take shots that would not be practical
otherwise.
Maybe you think that the only REAL camera is a view camera?
Jeff Peterman
Any insults, implied anger, bad grammar and bad spelling, are
entirely unintentionalal. Sorry.
http://www.pbase.com/jeffp25
here , look at this movie: http://www.dpreview.com/reviews/minoltadimagea1/Images/asmovie.movI have not read every response to this message but can anybody
movement ?
Why woyldn't we? it would not be really technically the same to do with a roll of film, i guess otherwise someone obviously would have done it by now.Am I the only person who does not think that this is a good idea,
As Einstein said, all movement is relative. Depends on the logic you use, but imho. the system just tries to keep the sensor still.Surely trying to get the light to focus accurately on a static
Probanly not much better, probably might even not be as goodm but as things are now i just have no IS-lenses that i use on a regular basis.Why do people think that it is going to be so much better than the
current IS system that Canon is using in their lenses ?
