MM1
Compare the sensors... On xxD, 5D and 7D, the AF points are formed out of single baselines, either one or two for a cross sensor. 1D AF sensor is completely different, where AF points are just segments of several long baselines of the AREA-SIR sensor.two entirely different AF designs? also later designs on the XXD series had major defocus - something the 1D may have calculated out based upon multiple cross types.Why can't I? 7D AF looks more like xxD AF on steroids, than 1D AF lite.30D TTL-SIR really has nothing to do with this thread and nor really can you make a straightforward jump between XXD series AF and 7D AF.
Even if I make 7D sensor a new design, it is more similar to xxD sensor than to 1D sensor.
BTW, what's "major defocus", please?
Of course I talk about the center point. But someone is wrong here... Either you or (for example) the guys who describe 400D AF on this page (couldn't find 30D description, but 400D should have the same AF):actually no they don't, and no they weren't. the 30D wasn't a 2.8 cross type at the center. it had "additionally sensitive" sensor regions, but werent' 2.8 cross types as the 1D series had. Slightly different. also I'm completely assuming here that you are only talking about centerpoint accuracy.Why? They both have the same "paper" specs.undoubtably .. the 1D's high precision sensor would be more accurate than the 30D's -
http://www.imaging-resource.com/PRODS/XTI/XTIA4.HTM
yes. depth of field is a measure of image size magnification to observer distance. if you view from a 30D and a 7D both at 100% magnification, you are very much increasing the image magnification, thus decreasing the appearance of DOF.Do you say that DOF (depth of field) is somehow tighter on 7D because of pixel pitch?however again that's neither here nor there when compared to a far more tighter level of precision required as the 7D requires.
It is. The post I was replying to was blaming lens mechanics for poor AF outcome. But poor lens mechanics would hamper the CD method also.not even close to being a good hypothesis.I was merely pointing out to my previous poster that blaming the lens' stepper motors is not a way to go. It's all about the AF system of the camera.where what you experienced may be true with the 30D to 1D .. however that's 3 generations older AF on even the XXD series.
Also, I believe that on 7D, the seemingly inaccurate lens would focus well in CD AF mode in live view. Although the mechanics of the lens is the same and it receives the same commands over the same communication protocol.
Of course. But even CD AF wouldn't be able to find good focus if the stepper motors were soooo terrible.CDAF is hill climbing so any PEC / backlash errors can be handled by the AF.
Yet, 1D can focus that lowly 50/1.8 better than any xxD. And 1D Mk2 N has also focus priority.on TTL-SIR they are not - it's entirely possible for CD-AF to settle at the "best focus" through ititeration .. on a fire and forget AF such as canon TTL-SIR it is not.
Gosh, my 50/1.8 is metal mount Mk1, made 13 years before EOS D30. Yet, it can be focused very well by my 1D Mk2 N which is 18 years younger.stepper precision can lead to more "imprecise" focus - especially on fast lenses - this would be a fact. the older stepper designs were based upon film tolerances.
How many times more accuracy does APS-H with 8MP need? I'm genuinely curious to know.a 7D requires 7 times more accuracy than film tolerances.
--compound that by the accuracy of the backlash calculations - can lead to focus being good / bad or indifferent from shot to shot.
then we have something called major defocus events - which are by nature far more imprecise .. and we carry imprecision from the AF calculations .. all the way through .. with each step adding more % of error into the mix.
where it may not be the entire reason - it's very much understandable that it's not helping the scenario.
Martin
