wordforword
Member
- Messages
- 19
- Reaction score
- 24
My gear:
XT-5 + Smallrig grip
35mm f1.4 + Glimmerglass. (52mm thread diameter)
16-80mm f4 + Clear filter. (72mm thread diameter)
As I'm doing a little more video with the 35 lately and the weather has been nicer I'm wondering what the best affordable option would be for for an ND and CPL filter setup that's somewhat futureproof in case I add or change lenses in the future.
I was about to look at 52mm diameter filters but it seems going larger and using step up rings makes more sense.
I suppose the 16-80 won't have much need for an ND with it's aperture being what it is but I thought maybe I shold get a 72mm filter anyway just in case plus CPL could be useful here.
I think the largest Fujifilm lens diameter is 77mm (16-55 and 100-400)
If I ever get either of those (or their succesors) then that diameter makes the most sense.
With all that in mind I started wondering about lens hoods fitting these different setups
Vignetting at wide end and colour cast etc are concerns too.
I would like to be able to keep using lens hoods. Will I need a screw in or universal rubber one? Can you even adjust a VND/CPLwith a hood on.
So many options so I'm a bit overwhelmed.
Anyone got a good set up they can recommend or am I missing anything important here?
