tool to open F20 case
Dave Martin
Ames, IA, US
The F20 (and I suspect F30/31/.... etc) has two security screws with a "Y" shaped head. They may be Tri-Wing #0000 size.
I want to remove the hot mirror but I have been unable to find a source for the driver needed to open the case.
I have tried a #000 Tri-Wing but it is too big.
Do you know where I can buy the appropriate tool?
I have the #1 Tri-Point, works fine on all my cameras (the complete F series).
Tim S
I am looking for the right tool also. Will you please post when you located the right one? Thanks! :-)
Jim
Digital Photography is liberating.
I believe you need a tri-point screwdriver, not a tri-wing screwdriver. The difference is the tri-point, each wing goes through the center axis, while on a tri-wing, each wing is a little offset.
