N
NCV
Guest
The EM5iii was also on my list to replace mt EM5, but when I saw several instances of the tripod mount breaking out on this forum, the EM5iii was eliminated swiftly from the list. I use a tripod whenever I can. Cost cutting corners were made with this camera.It's truly a great combination, I'm sure of it. Gives the Olympus tough competition.Te comparison you show is flawed. The plastic bottomed EM5iii is no match to the Z6 regarding construction quality and the Panasonic zoom is a cheap consumer grade lens no were near the 24-200 for optical quality.You made the decision to carry more weight, more bulk and spend significantly more money for something "more suited". I don't think anyone would be surprised that a larger, heavier, newer, more expensive camera produced better results than your old one.Ok, I recently renewed my camera gear cupboard radically.This is definitely not true, should be obvious to anyone, especially who has looked at recent discussions here.The main benefit rises from the crop factor 2, which really kicks in from about 100mm M43 focal length (200mm FF equiv). THIS is the last and only benefit of M43 to this point in time.What is needed are social media 'influencers' concentrating on fashion and culture, not photography influencers. Photography influencers are a bunch of old guys with bad teeth, who smell of pipe tobacco, and who use words like "copacetic".
Sorry guys, but this has GOT to be done.
Why say such strict "truths" which anyone can dismiss when they think about it for a second.
I spent quite some time weighing up the pros and cons of M43 verses other alternatives. I sold all my M43 and replaced it with a system which I felt was more suited to my photography.
I realize this question wasn't asked of me but as someone who shoots multiple systems - the short answer is the deliverables of modern cameras easily meet client demands which are increasingly more about timely turnaround (instant really) and videography. The shooting envelope of M43 is fairly large for stills and video. It's not as large as other formats, but the reality is, it doesn't have to be to produce excellent results. So then it becomes a matter of selection, packaging and pricing - all of which are favorable in M43.So I am well versed in the pros and cons of M43.
I would be interested to know your reasons for preferring M43 compared to the FF and APCS mirrorless systems which are gaining popularity.
My choice boiled down to the Z6/7 + 24-200 for a one lens solution or the EM1iii + 12-100. We are taking about similar build quality and performance levels
Nikon Z6/7 655g + 24-200 570g = 1225g Cost Z6II = €2190 + €970 = €3160
Olympus Em1iii 580g + 12-100 560G = 1140G Cost = €1780 + €800 = €2580
A tiny difference of 85g The heavily discounted Olympus setup saves just €580
Shopping around and buying as a kit gets the price closer and 87g is no big deal.
Differences between lenses are at least the constant aperture of Olympus for video. Nikon can acquire more light with that lens, Olympus has better IBIS. Obviously Nikon has better DR, but much worse frame rate for exposure bracketing etc.
Olympus has 12mm MFD at 0.15m, and at 100mm 0.45m. Nikon has at 24mm 0.5m and at 200mm 0.7m. This is important for some shooters without needing to change lenses.
Anyway, I compared those charts in the links. There aren't much better options to compare these lenses currently, but links are welcome. One shouldn't compare different tests, but we have no choice here, and many of those numbers seemed okay to me, similar curves etc.
What I found out, is that the Nikon has much better center sharpness, especially at 24-50mm when counting lw/ph. On the other hand what I found out, was that the Olympus has similar or better corner sharpness from 50-200mm.
Also one should note the earlier thread comparison where we found out that when shooting at f/8, the difference with the best Nikon Z 24-70mm f/2.8 lens is about 200 lw/ph, so with this lens Olympus could be equal or better.
I don't have time now to explain how I got these conclusions (which are not exact for sure because of different testers), but I can later when I have time if someone wants, and can't see it themselves.
Strange thing in that 24-200mm chart is the corner sharpness at f/16-f/22, where it is actually the same or even better for 50-200mm focal lengths. My logic says that this is not possible considering diffraction being a factor?
Btw. Only issues people I have seen thus far with E-M5iii being "plastic", is that it cannot be used with certain straps that use the tripod mount. I have seen nothing else related to build quality, other than some people wanting the heavier metal for the "feel". Which I can undestand, but Olympus opted for less weight.
The Lens Tip graphs need to be factored to take into account sensor size. Factoring this in makes the 24-70 far and away the better lens.
The big advantage for me is the fact that the FF sensor has far smoother colour and tonal separation. You lose that "gritty" M43 file look. We must look beyond specifications sometimes.
https://www.lenstip.com/591.4-Lens_review-Nikon_Nikkor_Z_24-70_mm_f_2.8_S_Image_resolution.html
https://www.digitalcameraworld.com/...28-s-review#section-performance-and-lab-tests
https://www.lenstip.com/497.4-Lens_...ED_12-100_mm_f_4_IS_PRO_Image_resolution.html
https://www.digitalcameraworld.com/reviews/nikon-z-24-200mm-f4-63-vr-review#section-lab-tests
