Interesting that you're also using a Panny. The GH1 was a ground breaking camera, essentially popularising the idea of hybrid stills/video and introducing that mult aspect sensor.
I've been through a number of Lumix cameras (G1, GF1, GH2, G3, G6) and they seem to get better and better with every generation.
I find the G6 to be an almost perfect SLR substitute.
It's small and light (but not too small and not too light) and controls are better than earlier generations which makes it convenient to use. It's shape fits my hands very well - which is not true of a lot of mirrorless offerings which still seem to struggle to find the right form factor.
I stil have a Pentax K5 which is the best camera in terms of build, features, ergonomics and overall image quality I have ever used. It is beautifully build and fits my hand like a glove. But even though it is tiny for a pro level DSLR, I don't enjoy lugging it around or its bulky and heavy lenses, and the G6 is good enough to replace it for everyday shooting.
For me, at the moment, the G6 is the best fit SLR alternative, but there are still improvements I'd like to see:
- I prefer thumb operated controls to shutter finger controls as you don't have to take your finger off the shutter release, so I'd like a "G" that was similar to the G6 but which included a second rear command wheel for exposure comp - a dedicated one like Fuji/Sony would be ideal. And I'd like the wheels to be bigger.
- I'd like a dedicated dial for ISO positioned on the currently empty left shoulder rather than the push button + command wheel style
- the menu system could be clearer and tidier and they could settle on labels that make sense!
- the EVF display could be improved by making the option that creates separate areas for the view and the settings put a neat border all around the viewing area rather than just along the bottom edge. Moving all the settings icons and displays to this border. Let you to program the display to show only the settings you want. I like things minimalist but if I turn off the detailed display, I also lose the preview histogram which I want!
- If you are going to use a touch screen LCD, don't make it sensitive to accidentally touching things like AF point.
- Separate doors for SD card and battery
- improved materials and build so it doesn't feel quite so cheap - more rubber on grip.
- Slightly more prominent sculpting of the grip to give a more secure grip and prevent accidental pushes on buttons by the palm of the hand
- It uses the oversized multi aspect sensor from the GH2 but doesn't do mult-aspect! Make use of it and offer more ratios. Aspect ratios are important in composition and mirrorless cameras are ideal for allowing you to use them as a basic control. Why not exploit this to the max?
- I wonder if would be possible to design a LCD hinge that could offer the choice of sticking out the side or flipping up down in place...
It amazes me how good (non Sigma!) cameras have got in form factor and functionality but how there is still always room for little improvements and customisation to taste...
There's no blotching on the various colors shown, however dark they are.
. . . very much used DP2M will be here on Sunday, and I can do my own blotch tests, or just take some photos around.
Once, I lit a letter-size white card (in portrait orientation) from about a foot above with small light bulb - so as to use the 'inverse square law' to get a gradient of illuminance down the paper. With the right exposure, the onset and fade-out of the infamous blotching is quite evident.
Ted
That is a clever trick, to get "fading" light effect. But then again, if there is no cure other than to add more light, the real life photography should take place under conditions the camera is able to produce decent result. To be honest, I think, as well as most other that there is no other way, but to use the camera in the limits of its capability. Sigma has the "mechanics" and software, so one must be humble and use what is given.
I couldn't agree. I study and test this kind of thing so as to "know my enemy".
As to poor light or close-up stuff, I am beginning to use my Panasonic m4/3 GH1 more often than hitherto.
Ted
"...while I am tempted to bludgeon you, I would rather have you come away with an improved understanding of how these sensors work" ---- Eric Fossum
Galleries and website:
http://www.whisperingcat.co.uk/
Flickr:
http://www.flickr.com/photos/davidmillier/
