tko
Just have to set the record straight. I firmly believe that the poster_formally_known_as_Joe's equivalency theory is totally correct. It's very straight forward and I don't understand why people are upset with it.
For example one poster stated : "I have never accepted his "equivalence theory" and never will. It is plain wrong. It contradicts every book on photography that I have ever read; it makes a mockery of my light meter readings."
How does it "make a mockery of light meter readings?" It's just a simple way to compare different sensors on the same footing. Granted, nothing is perfect, but if you insist on comparing systems Joe's theory is the way to go.
My explanation of its opposition is that people take the word "equivalency" much too strongly. In engineering it doesn't mean equal, it's just a useful way to compare things. 10,000 lbs of TNT may be equivalent to one atom bomb, but they are NOT equal. One is a lot heavier, for starters : ) A pound of feathers weighs the same as a pound of lead. That doesn't mean they are the same.
Equivalency just gives you a useful way to help you think about things and make comparisons. It's down and dirty, hands on, practical engineering. Whenever your use "equivalence", you have to use it in the spirit in which it was given. To use my lame example with the TNT, if you were to reply to my statement by saying “10,000 lbs of TNT is NOT equivalent an atom bomb because they are different colors," wouldn't that sound like a stupid reply? Misses the point and is technically correct but totally useless. Equivalence lets us visualize things in terms we understand.
Consider focal length and crop factor. To find the equivalent focal length we multiple by the crop factor. True, the real focal length doesn't change, but it behaves as though it does - for us photographers. That's why it's the EQUIVALENT focal length. It's a very useful concept that allows photographers to quickly visualize how different sensor sizes affect the FOV. If you’re an optical designer you wouldn't use this concept.
Engineering definitions exist because they serve a purpose and are useful. Focal length itself is a definition that some people found useful. So are F-stops and ISO. If you’d never heard of them they’d sound weird. Why the h*ck would you divide the focal length by the diameter of the aperture? The usefulness has to be explained.
Changing sensor size effects DOF for all practical applications. You don't have to write the equations out, any beginning photographer knows that a prosumer has a lot more DOF than their old FF at the same F-stop. You can slice and dice this a dozen different ways, but the presented viewpoint is the most practical way to look at things FOR photographers. Not for physicists.
Lastly, a larger sensor gathers more light for the same lens. How hard is that to grasp? Yes, there are lots of interesting subtleties here, all of which I'm aware of. So? The basic statements are not changed. For example some people will argue that equivalent focal length is really a function of pixel density. That's true, and may represent a higher truth, but is that a useful equivalency for everyday use?
You can put all the equivalencies together and it becomes a nice, simple, unifying theory. Multiple the FL, aperture, and ISO by the sensor crop factor to see how the performance for one sensor compares to the performance of a different crop sensor. For example, if you have a prosumer with a 4.0 crop factor sensor, and are shooting F8, 100MM and ISO 1600, when you change to a FF sensor you'll need about F2, ISO 400, and 25MM. Less noise, more DOF, a wider angle lens. That's not a mathematical statement, or a position of higher physics, it just lets you visualize how the change would work. So why is this so controversial?
Notice that the exposure, angle of view, DOF, and noise stays about the same with the crop factor equivalency applied. That’s exactly why we did this. Not in search of any higher truth, but because it helps us! (I still don’t see how this makes a mockery of a light meter)
You want to argue about this? Then give me a better equivalency by answering this question; given a 4.0 crop factor, F8, 100MM, ISO 1600, what settings would give the most similar photograph if you changed to a full frame sensor? That's all equivalency is about.
You can ignore this equivalency. You don’t have to use other imaginary concepts like F-stop if you don’t think they benefits you. Doesn't affect real life, doesn't affect lens designers, doesn't affect CCD designers, doesn't affect nuclear engineers. Just a simple little equivalency that lets you visualize how, when you change one thing, everything else is effected.
If you got a nice fast prosumer with a F2 lens like a G9, and you want to move up to a dSLR but can only afford a F5.6 lens, equivalency gives you a simple way to compare performance. Will the noise be better when you get the kit dSLR? Will the DOF be more or less? All types of complex questions can be answered very simply by using equivalency.
Now, if you’re a photographer and you've just use one system, and you never plan to use any other system, then you don't even need to think about equivalency. But lets say you borrow your niece's point and shoot, isn't it nice to know that at F4 you'll have the same DOF as F16 on your full frame system? Lets you feel right at home just by modifying the old rules. You can still use your FF intuition, developed over years of use.
I'm not really interested in why you may think the above equivalency is wrong. I don't want to hear why you think the Moon Landing was a fake, or why the Earth is really flat, or why a pound of feathers isn't really a pound of lead. Just not interested, don’t want to play word games, not starting a flame war, not knocking any system.
For the rest of you, I am interested in why and what you think about equivalency is so controversial? Why do people want to fight it so hard?
