GeorgianBay1939
This is a continuation of " Two functions of a camera's ISO dial." which ran out a few days ago.
First let me apologize for disappearing after starting a controversial thread. Health issues intervened and I learned some things other than the functions of an ISO dial. :-D No, I did not abandon DM's Ship of Fools.
_____________________
I decided here to separate the two functions, metering and mapping, so that we could drill down to clarify each function.
An email (from an accomplished photographer) said, "I don't know and I don't care." So I should tell you why I started the thread in the first place:
A couple of weeks ago I heard a well-respected, experienced, ex-film, photographer answer a question from a youngster who had just added his first full frame camera to his collection of gear. The youngster (in his 50s) was a beginning raw shooter who was learning to stretch his envelope. Good science background and a bit of a perfectionist. Kids grown up and he was developing a hobby.
In answer to the question, "What does the ISO dial REALLY do when I change it?",
this is what the older photographer said,
"You are changing one of the three brightness variables so that you'll have to change either f/ or ss to get a proper exposure. The ISO dial is calibrated to give you optimum exposure in varying light conditions. Turn ISO down in bright conditions, up in dark conditions. Increasing the ISO setting increases the sensor's gain to compensate for lack of brightness in the scene."
After thinking about it, I realized that the above explanation would limit the growth of the youngster and contemplated how I would answer such a question when asked by a developing (!) photographer.
"Two functions of a camera's ISO dial" was my first attempt at forming such an answer. After reading the thread I realize that both parts, metering and mapping, of the answer needed improvement. Since the metering portion seemed to be almost ok, I would ask that you limit your comments to the metering portion of the answer in this thread. I will start a thread to deal with the (much more controversial) mapping portion later.
_________________________________________________
Here is the context:
What do changes to the ISO dial do to a camera’s inner workings?
1 It changes the set points of the camera's exposure metering system, (EMS).
2 It changes the tone values of the output image by a combination of sensor level gain adjustment and by modifying the tone mapping of exposure to output image.
Item 2 seems controversial and will be put up in a later thread.
___________________________________________________
Back to Item 1: It changes the set points of the camera's Exposure Metering System, (EMS).
1 (a) What does the camera's exposure metering system (EMS) do?
The EMS measures (normally through the lens) the average luminance of the scene, L, and based on that measurement and a factory calibration of ISO Speed, S, the EMS recommends a pair of exposure settings, N and t (f/ and ss) to give a good image result of the exposure. The factory calibration complies with the ISO 2720:1974 Standard to establish the relationship between average scene luminance, L, and recommended camera settings, N and t, for a selected ISO setting, S, for that particular camera model.
1(b) How does changing the ISO setting knob change the EMS recommendations?
Based on the measured average scene Luminance, L, and the calibration curves installed at the factory the EMS will return recommended EV settings , N and t, according to the Exposure Metering Equation , programmed into the EMS :
View: original size
For the above equation to be valid for a measured average scene luminance, L, the recommended camera settings, (N^2)/t , will change with changes in ISO speed, S.
Therefore for every setting of S, there is only one (N^2)/t (and only one pair of N, t) that will satisfy the equation.
That pair is the recommended exposure that the EMS offers to the photographer.
Therefore for a given average scene luminance, L, every time the ISO knob is changed, S is changed and the recommended exposure settings, N, t, (f/,ss) will change. Also, every time the average scene luminance, L, is changed (as measured by the meter) the recommended exposure settings will change, even if the ISO speed, S, is held constant.
The above paragraph (and its underlying equation) relates Exposure, (which only depends on L, N, t,) and ISO Speed, S, to give a "good image result". Two parts of Exposure, N and t, and ISO Speed, S, are sometimes crafted into an "Exposure Triangle", which should be read very critically as it is often leads to false conclusions.
This relationship of N ,t and S is easily seen when using the P(program) Mode in a camera: For a given L, adjusting S will change the exposure pairs. And, for a fixed L and S, changes in N will cause changes in t and vice versa.
[The definition of Exposure Value = Log_2 ([N^2)/t] is no accident as it puts all of the above in "stops", making relationships of exposure variables simple.]
The outputs of the EMS, the exposure settings, inform the various AutoExposure (AE) Modes [(P(rogram), A(perture), S(peed)] of the Mode dial. Some cameras have fully Automatic and/or Scene Modes which are also informed by the EMS.
It is important to note that the above is only valid when the photographer is using an AE Mode or is following the meter recommendation in M(anual) Mode. If the photographer disregards the meter recommendation (by using M(anual), Spot Metering with AE(lock), LiveView Histogram, or blinkies, etc) to inform his/her exposure decisions, the above equation is invalid and EV (and consequently exposure, Hv) is totally independent of S for any L.* Exposure compensation shifts the equation to provide a "compensated" recommended exposure pair.
* In this case the photographer is probably using independent camera settings (subject to artistic constraints regarding motion blur and DoF/Diffraction) which would optimize raw file outputs in terms of highlight protection, minimum noise and maximum PDR as opposed to recommended camera settings which would normally return an output image with a standard acceptable brightness.
I would ask that you review and criticize the above. Please restrict your comments to the metering function of the ISO dial. I am sure that there will be a lot of other opportunities to add to the discussion of the other function of the ISO Dial!
Please no plagiarism or excessive noise, like this static:
http://www.dpreview.com/forums/post/57259249
http://www.dpreview.com/forums/post/57259530
Many thanks.
Tom
The best part of growing old is having the opportunity to do so.
View: original size
Many thanks.
Tom
