Flying whale
New member
- Messages
- 5
- Reaction score
- 0
I have Panasonic s5 and I'm using the Xpro-O trigger with the V860ii-O flash.
When using the trigger, everything in manual, there is noticeable lag before the flash after I have pressed the shutter button. If I test the flash with the test button on xpro there is no delay, only when using the camera's shutter button. On-camera flash has no delay. Only solution I've found is to use only the center pin on the Xpro and then the delay is gone, but the trade off is losing all the ttl and hss functions. Is this something that can be fixed or a problem I need to live with? I've reset everything, updated all the firmware and tried every setting on the camera I can think of.
I feel like the S5 treats the trigger as if the TTL is always on even when the flash system is set to M.
