Susan S.
text snippedThanks for sharing your experience. I agree that there is no point using JPEG's if you don't get the white balance correct at the outset - which is why I too use custom white balance on nearly all shots unless AWB will clearly suffice.
I try to bypass the noise reduction issue by staying at the lowest possible ISO's. Do you find the G11's noise reduction detail loss at low ISO's objectionable?
Your NR workflow sets an admirably high standard, but for me (just my opinion) falls into the category of time I would rather spend taking photos, so I compromise.
I'm still trying to decide whether I can live with the noise reduction at ISO 80 and 100 in jpegs. I'd just shoot RAW plus jpeg until I worked it out, but if you do that you can no longer reduce the sharpening and contrast in the jpegs and the default level of sharpening is way too high for my tastes.John TF
The other thing that DPP does better (and it does very much better) than the jpeg processor in camera is chromatic aberration and purple fringing correction. The way that DPP deals with it is nothing short of miraculous. I was shooting jacaranda blossom against a grey sky this morning (in the rain!) and the jpegs had purple fringing from hell along the branches (it was a real torture test for the camera) and noticeble red/cyan chromatic aberration along the picket fence. The DPP processed RAWs had virtually none. While it's possible to remove the purple fringing from the jpegs it's a bit tiresometo have to do it. (the red/cyan CA is much easier with the photoshop lens distort filter)
Some of the least worse of my photos:
http://www.flickr.com/photos/susans/
