Battery_Kinzie
Well-known member
- Messages
- 162
- Reaction score
- 337
How do you do it? As in, how does your workflow look and how do you stop it becoming a massive mess? I'm speaking mostly to those who take RAW + jpg, and then decide later which to use - i.e. if the jpg looks good then use that, otherwise maybe play with the raw and see what you can get out of it.
With my Sony cameras, I used to just shoot RAW and edit & export those, but now that I can often get good results with a relatively straightforward Fuji 'recipe' (and importantly, can't easily replicate these results in Lightroom), this becomes somehow more complicated. And I'm still not quite so skilled with getting the exact results I want in-camera, so I end up editing RAW files quite often, even if just some small changes.
This gets quite messy though, since I now import both jpg and raw, check the jpg if I like the photo at all (if not, I flag both jpg and raw for deletion), then check if that JPG is good enough or if maybe a quick RAW edit might be worth it. If it's good, I leave it - if not, then I edit the RAW. So for one walk around town, I might end up with say 20 photos, 10 of which the SOOC jpg was good enough, and 10 where I want to do some edits. But I'm not really too happy with how I'm doing it now, since it ends up all over the place, with some JPGs which I don't like, some corresponding edited RAW files, some un-edited and not-needed RAW files, and so on...
So, how do those of you who shoot, and use, a mixture of jpg and raw keep your lightroom/capture one/whatever library somewhat healthy?
I feel like this post itself is also quite messy, so I apologise. I'll try to explain my predicament a bit more later, if more precise details are needed.
