thielges
Leading Member
I fixed the worst problem with my LX10 though there remains another less critical issue: manual focus won't work. Neither setting the camera in MF mode nor DMF focus after autofocus work anymore. My workaround is to use spot focus in place of MF though that is awkward and doesn't work in some situations.
What puzzles me is that I cannot figure out what component in the camera has failed. Certainly the mechanism that moves the focusing lens around is working just fine, otherwise autofocus would not be working. So I initially thought that the "focus by wire" control activated by the lens outer ring had failed. It could be something as simple as a faulty electrical connection between the ring and the controller electronics.
But then I noticed that the camera does indeed respond to turning the ring. In both MF and DMF modes the camera turns on the focus assist magnifier in the viewfinder. But twisting the ring doesn't change the focus at all.
In my experience these focus by wire controls have a very simple interface, they just send a series of pulses down a wire, the number of pulses are proportional to how far you twist the ring. So the ring is at least sending one pulse, otherwise the focus assist magnifier wouldn't appear. I cannot however figure out how that focus control would fail in a way that it sends just one pulse instead of several.
If you have any ideas please let me know.
