With DXO releasing new versions of their software that includes R5 II support, I'm now evaluating Pure Raw, especially the Lightroom plugin. What I'm trying to understand now is how to get the settings of the processed file in Lightroom to be the way I want.
If PR makes lens corrections, LR should not. It seems like it defaults to applying them. So that could be my default LR settings. On the other hand, the color profile is definitely not my preferred color profile (Neutral). Other edit settings have adjustments, like shadow adjustments and other similar things in the develop module.
What settings are applied? Does it retain settings already applied to the photo I'm processing? Or is it using default settings set somewhere? If so, where do I set those? And can I set them separately for this sort of import vs. a normal import of raw files from the camera?
Annoyingly, things like keyword tags and star ratings are NOT retained. I would like these retained from the original image. Is there a way to set it up to do that? I don't mean syncing afterward. I know how to do that, but I shouldn't have to.
Scenario: I have Lightroom filtered to display images with a star rating of 4 stars and keywords containing "DXO". I select File, Export with Preset, Process with DXO PureRaw (one of the items). The image is processed and imported into a collection. Then the screen goes blank because I've filtered on 4 stars and "DXO" but the newly imported file has neither of those, and now it's not even displaying the source because it has switched to the collection.
