bill dennis
Forum Enthusiast
No problem - OK, I have tested with v1.6 on my OM-1 and I can confirm that with OI Share on my Pixel Android 14 I am getting the same result - exposure settings are not saved / restored in the custom sets. It seems to happen every time for me - for small values of "every time"Now that you are on 1.6, can you save and restore settings with the phone without the settings corruption, or does it happen every time?
Here's some detail of what I did if it helps, lots of screen images etc
1. Having set up my custom modes previously, I saved all settings to a file with OI Share - everything in one file.
The saved file looks like this in OI Share - you can see it records the firmware version v1.6 in the file
My C1-C4 custom set SCP screens before the save / restore show exposure settings like this - my intended exposure settings (and they restore OK on the camera when I turn the mode dial):
* Note: All my custom sets are in the "reset" mode (not hold), it may be a relevant difference to your setup. C4 SCP image looks different because I have the LCD live view enabled for astro settings and just pressed OK to show the SCP for the photo.
2. I do a reset of the camera on this menu screen, Initialise all settings
* Note: It does not clear everything, for example your copyright info is preserved and so is time zone. The manual tells you what settings are affected by this reset function.
3. After the reset I checked my custom modes
All my custom sets C1-C4 are now set to "P" mode like this
4. Now with OI.Share I restore my saved file for all settings
After the restore the camera restarted and I checked all my custom modes C1-C4 and I can see there are exposure differences for some of them. They get the defaults of 1/250s or 1/320s for shutter (depends on SH2 mode being set) and f5.6 for aperture. I have the 17mm f1.8 lens attached so the f5.6 is not due to the attached lens. You can see exposure settings in my C1, C3 and C4 custom modes got messed up with the restore. C2 used the default of 1/250s that I left from last time. For my C3 and C4 settings I always want the aperture to be wide open for the attached lens so this is an issue I have to correct in those slots.
Look at my C4 astrophotography settings - instead of 15 seconds at f1.8 it is now 1/250s at f5.6. To correct this I have to attach a f1.8 lens. I didn't have any exposure comp set in my custom settings before this so actually I don't know if it is preserved but from testing with the previous firmware it wasn't.
So apart from the OI.Share platform I'm wondering what the difference is for your own setup when you saw the exposure settings were restored OK. Did you do a reset or change any exposure settings in you custom modes before restoring?
It seems to me that the settings restore doesn't change the exposure settings in the custom slot to some random setting - it just doesn't over-write what is set on camera (it may be the defaults or something you saved due to the "hold" mode).
Also it is not clear if this is an issue between OI Share platform implementations or OM Workspace platforms etc without some thorough testing. OM Systems should be doing this and should really clarify the situation.
I can check this again on the iPad before I restore my exposure settings to see if it is the same on iPadOS.
Bill
