DNBush
Leading Member
- Messages
- 822
- Solutions
- 4
- Reaction score
- 641
Looking at the specs for the OM-1 Mark II it says...
Up to 8.5 EV steps* ((Body only))
Up to 8.5 EV steps** (Sync IS)
Based on CIPA measurement conditions
*When using M.Zuiko Digital ED 12-40mm F2.8 PRO II. Focal length: 40mm
(35mm equivalent: 80mm)
**When using the M.Zuiko Digital ED 150-400mm F4.5 TC1.25x IS PRO.
Focal length: 150mm (35mm equivalent: 300mm), halfway release image
stabilisation Off, Frame rate: High
So this seems to imply that lenses with Sync IS (12-100 f/4 for instance) no longer add anything to the stabilization.
Am I reading the right?
I know for lower range bodies like the OM-3 which has only 6.5 stops in body, Sync IS still adds some, getting you up to 7.5 stops.
But this makes it sound like the OM-1 Mark II has maxed out via in body alone.
