Nikon z6 images go blurry with IBIS
Status
Not open for further replies.
As tittle , I found that image can go blurry with IBIS on and shutter speed from 1/160s to 1/50.
top left:IBIS on , EFCS off
top right:IBIS off , EFCS off
down left:IBIS on , EFCS on
1/160
1/100
1/80 Worst one of all shutter speed
1/50
1/25 back to sharp
In conclusion , you may want to keep EFCS on when you need IBIS.
Don’t know NIKON will fix this or not.
Probably won't fix it, as it's also a problem on the Z7 (more obvious on the Z7). I strictly keep EFCS on on my bodies as I rarely shoot above 1/2000s (which is the one caveat to EFCS, it tops out at a 1/2000s).
Gladly someone new that has noticed this problem. There is recall for Nikon z6 and z7 with IBIS problems, but they won't fix serial numbers that are not in that recall list. That is the disappointing part.
You can leave it at AUTO and it will know when not to use Mechanical Shutter, they are aware of this problem, that is way they added Auto Shutter in the firmware update. This way your camera will go over 1/2000s on Mechanical Shutter. The blurry images appear mostly at speeds under 1/320s, over 1/320s the Auto switches to Mechanical Shutter.
EFCS has many disadvantages, banding with flashes or indoor lighting, you cannot shoot sports, etc. - some say even raw files are affected. In my opinion EFCS is not an option for a pro full frame camera, especially when the Sony a7iii does not have this problem.
I sincerely want Nikon to be responsible and fix it.
I'm a bit puzzled why they won't fix yours... My z6 wasn't under recall, but my z7 was. However, I haven't found evidence of either problem (banding or blurry images) in the shots I've done. I use EFCS almost all the time. I also have mine explicitly set to use EFCS.
Imagine how I feel, being Nikon user for over 10 years. I have made the mini site, send the camera with the card in it. They said that the camera is in working parameters but they won't show me what they have tested, some sample images.
Interesting that your Z7 was recalled, but using EFCS is the kind of the "fix" and that is why you did not notice. Now I mostly use EFCS to avoid the blurry images, but sometimes I cannot use EFCS due to banding with flashes or some interior lights and then I have to turn off the VR to use the Mechanical Shutter.
If you have the time, you should do some tests with your Z6 and Z7 like in my mini site, all settings and examples are in there. I am really curious to see a difference between the z6 and the recalled z7.
Mine was recalled for IBIS which I'm sure you were aware of (the purpose of the recalls).
Unfortunately, shutter shock has been a problem on various DSLR models from Nikon, even going back to the D5500/D5600 and even the higher resolution DSLRs like the D810 and D850.
Yes it's not good that EFCS is their temporary "fix". Just doing quick Google search and it seems even some of the earlier Sony cameras had the same issue. Hopefully with the next gen cameras this won't be an issue or it will be addressed. I personally haven't seen any evidence in my shots shooting around the settings you discussed.
I'll do some more tests, particularly with my Z6 since that's what you have, and see. I'll try to do some Z7 tests too but it may not be for a week or so.
1/160
1/100
1/50
1/25 back to sharp
Shutter shock normally appears using Mechanical Shutter with the VR on and also with VR off in the same situation. In my case it appears only with the VR on. The VR off images are sharp while the VR on are blurry. I own a D850 and it's in the test, same test on the mini site, it does not have shutter shock, same settings, same test :)
It depends on the settings really, that's why maybe in your line of work you did not notice. But when doing the tests set the cameras exactly like in the mini site, all info is there, very well explained.
No worries, when you will have the time, it's fine by me. Million thanks for the help!
I don't know any company that fixed or recalled cameras for shutter-shock. My Panasonic GX8 ruined lots of shots because of that (IBIS notwithstanding) and the only solution was the electronic shutter.
This is not the classical shutter shock, this happens only when the VR is on, if i turn off the VR the images are sharp, what's the point of that IBIS if it cannot be used with a Mechanical Shutter, a DSLR+VR lens works flawless. Also Nikon has a recall for the Z6 and the Z7 with VR problems, but my serial number is not in their list and they say that my camera is ok.
Comparing with your Panasonic, there is a price difference between the Z6 and the GX8. But let's ignore that and think that the GX8 is released in 2015, I have also heard that Sony had some similar problems with their first model. The Sony a7iii (similar price and specs) works perfect, without any problems as you can see in my tests (tripod or handheld).
So thank you Nikon for making a camera from the past and sell it in 2019 for the same price as a good Sony a7iii. I got tricked because I had a lot of Nikon glass, but guess what the FTZ is slow on focus and the worst part is when using a VR lens with the FTZ, the images are horrible blurry, as seen in my tests.
Test your Z6 or Z7 for this problem: https://z6blurry.000webhostapp.com
The Auto Shutter was Nikon's lame attempt to fix the VR issue with a firmware update.
Really? Every camera experiences shutter shock to some degree, and EFC shutter is a common solution to this.
When I first bought the Z6 it didn't have the Auto feature just Mechanical and EFCS, also Canon EOS R and Sony a7iii does not have this Auto Shutter option.
So Sony makes you do it manually, and my Canon EOS RP has a totally bastardly implementation, and Fuji only offers EFCS on two models. And yet I've been shooting with all those cameras without any problems. Complaining about Nikon is even more ridiculous because it's probably the best solution.
Yes EFCS has a lot of limitations, especially banding when using with strobes / flashes and indoor light. Also you cannot shoot fast moving objects with EFCS.
How is that? The electronic first curtain moves with the same speed as the mechanical shutter. There are known effects on bokeh and noise but those are negligent, and so far I haven't seen anybody did the measurements for Nikon anyways.
You can search the internet EFCS disadvantages, some say even raw files are affected.
For example?
This is not the normal shutter shock, this only happens when using Mechanical Shutter + VR on. The images made with Mechanical Shutter + VR off are sharper than the ones with VR on (handheld and tripod), see on the mini site in my signature.
This is exactly normal shutter shock. The stabilization system, whether optical or IBIS, more often the latter, is responsible for exacerbating the problem at certain frequencies. The first cameras that experienced that were Olympus, when they first introduced IBIS and that's when it became a favorite discussion topic. By now everybody should have heard about the effect of the shutter shock on IBIS.
No... Sony does not have this problem when shooting with a Mechanical Shutter + VR on and it does not need the Auto Shutter.
You obviously don't have experience with Sony. It does have the same problem. The difference though is that Sony IBIS is very inefficient, so the contribution of IBIS is also less pronounced. But Sony's shutters have been pretty strong and noisy, so likely producing more mechanical shock. Sony also won't switch automatically to the mechanical shutter at high SS, which comes with its own problems. When I shot with A7iii I was always using the EFCS, which is on by default.
Shooting with EFCS is the photographers choice in what he needs.
EFCS doesn't move at the same high speed and also not in the same style.
Whoa, where did you get that? Not only it does move at the same speed as mechanical, it must or you are screwed.
The Electronic Shutter on these cameras move pixel by pixel, one line at a time,
You are confused and obviously don't know the physics of these processes. The EFCS only resets the capacitors, which can be very fast, the second mechanical shutter is what is responsible for correct exposure. Readout is not a problem, because the second shutter remains close as long as necessary to finish.
producing the banding effect when using strobes/flashes or with some indoor lights. Also for high speed photos the EFCS cannot keep with the Mechanical Shutter and produces the rolling shutter effect.
If you look at a thread here called "Z firmware wishlist" you will see that the first on that list is "- fix the banding" - banding appears if you use EFCS, only fix for the future cameras is to add a global shutter and not a rolling shutter. But with the Z6 and Z7 the only way to avoid banding is to use the Mechanical Shutter.
If this is an endemic problem (like Nikon's focus issue with the D800) I would be inclined to go in to Nikon and explain it to them in person. A friend did this with his D800's. If it is a system issue, then Nikon might have to do a recall.
1/160
1/100
1/50
1/25 back to sharp
When you were shooting were you on a tripod or handheld?
1/160
1/100
1/50
1/25 back to sharp
If you look at the mini site the first tests were on a a table, so they are like on a tripod. The last tests are handheld, were for example a photo with Mechanical Shutter + VR off is sharper than a photo with Mechanical Shutter + VR on, you can see that image in the last test "Handheld Store Tests Z6, Z7 and A7iii". In my opinion that makes the VR useless. So tripod or handheld the results are the same.
For example?
If that is exactly normal shutter shock, how come the d850 + VR lens or the Sony a7iii don't have it, see my tests on the site, same situation same settings. You are talking from the past with Olympus and yes I heard Sony had a similar problem with their first models in the past, but we are in 2019. In 2019 Sony a7iii does not have this problem although indeed the shutter seems noisy, see my tests, Sony passed the same tests where the NIkon Z6 failed. And I am used to Sony cameras and Canon cameras, all have disadvantages and advantages, but in my opinion Nikon has a problem now in 2019, this is not a disadvantage. A disadvantage would be to not have IBIS like the Canon EOS R, but maybe that's why Canon went for the classic lens VR. Nikon added IBIS in 2019, that should have worked good like on the Sony a7iii. Nikon also have a recall for VR problems on the z6 and z7, search the internet. And those who got recalled did not notice the difference of sharpness, why? Because it's not always visible or they used EFCS. My serial number is not in that list, all I want is for Nikon to accept other cameras with other serial numbers to fix it, like they fixed others.
The EFCS has known and real disadvantages(more than one), tested by others, search the internet and you will see a lot more.
About EFCS in the Z6 or Z7. When using EFCS the shutter speed will go up to 1/2000s compared when using Mechanical Shutter it will go to 1/8000s, So I am screwed.
For example?
The D850 has much higher mass than the Z6, so I'd expect it to be more stable in hands. That's pretty normal.
You mean in YOUR tests Sony performed better. So what...? Also, personally I refuse to believe that Sony would not have problems with shutter shock. The one I tested certainly was not only MUCH noisier, but when the shutter was released it felt like somebody hit my palm, so I am sure that has a MUCH bigger negative effect than anything I ever experienced.
I don't know much about the Sony IBIS, but as far as I know, it isn't as efficient as Nikon, so what exactly are you wishing for?
We all know that, it's on Nikon site you don't need to search the internet.
So you mean you are the only one who recognize this "problem" and know how to test it and repeat it... :-)
Nikon repairs ALL cameras but there must be a defect to be repaired. If you can't show the problems and it won't be repeatable in their test bed what do you expect them to do? If your camera is still new enough you can just return it, but if it is no longer new enough then you must claim warranty.
Like what...? The only disadvantage I know of is the limited shutter speed. Everything else is hogwash.
Banding due to certain type of light is NOT related to it. In certain light you WILL get banding, regardless of shutter.
In which way are you screwed? I mean, seriously, if you dislike EFCS there is a VERY simple solution, don't use it.
1/160
1/100
1/50
1/25 back to sharp
And you turned off VR when you were on the table?
For example?
I should not answer you message because it's clear you did not look over my tests. I did not test the d850 handheld, I have tested it on the table (or tripod) where the shutter shock should appear when using the VR or not. In both situations the d850+VR lens performed flawless. Please see all tests on the site.
As I said, yes it does seem to have a noisy shutter, but the IBIS is not affected by it, which is not a problem like on my Z6. And I have tested so far 2 Sony a7iii, one Sony a7rIII and one Sony a7RIV, the Mechanical Shutter does not shake the IBIS. Don't believe me, borrow a Sony like I did, do the tests. I did tests before I have made that site and talked here.
I am glad you know that. Search on the internet means that it will lead you to the Nikon website for your country.
No, I am not the only one. I did not start this thread and there are others that notice this. Some of us really have this problem compared to some that got their camera fixed by serial number recall or their camera is performing ok. My whole point is that the recall should be extended. My camera is in warranty and I have sent it to them, but got refused because my camera does not have the serial number in the list. Now I am actually talking to them, explaining and showing the site and all my tests. Still waiting for an answer and hopefully for them to fix my z6.
About EFCS, I have explained over and over again, we all know it has disadvantages, search the internet and threads here if you don't believe me. Also look at the thread here "Z firmware wishlist" the first on the list is "- fix the banding". Banding appears using EFCS, the fix is to use Mechanical Shutter, using Mechanical Shutter in combination with the VR makes the images blurry. Than my only option is to disable the VR, especially when using strobes/flashes. So that makes the VR on my z6 useless in some situations.
The screwed part is related to the previous comment, where "forpetessake" said: "Whoa, where did you get that? Not only it does move at the same speed as mechanical, it must or you are screwed." And i explained it does not move at the same speed, meaning that I am screwed. And it's not a matter that i dislike EFCS, I use EFCS in daylight landscapes for example, it's just a matter that EFCS in some situations does not work for me, forcing me to disable VR, once again making the VR in my z6 useless.
And in the end I don't understand why some users are throwing rocks at other users that need help. If that is the point of this forum I will stop posting here.
1/160
1/100
1/50
1/25 back to sharp
Yes, on the table I have two tests pointing the same issue.
Mechanical Shutter + VR on - blurry image
Electronic Front Shutter Curtain + VR on - sharp image
and
Mechanical Shutter + VR off - sharp image
The level of sharpness between Mechanical Shutter + VR off is the same as EFCS + VR on. Which proves that it's not the normal shutter shock, and it's an IBIS Shutter Shock which is not normal for a 2019 camera, where for example a Sony a7iii (similar specs and price) performed flawless in all situations. But it may be my z6 and those I have tested to have this problem, maybe others do have good ones. The idea is that i want mine fixed.
For example?
...but I did look at your "tests", and I think you doing it wrong. There is not much more to say about them. I think you totally misunderstood how IBIS is working and when it should be on or off. If you think you have a problem with your camera you should contact Nikon. Continuing this war here is just pointless. You made your point, but you are not listening to anyone. You have also hijacked a thread to your agenda. This is against the rules and is very rude.
For example?
Misunderstood the IBIS? ... it's beyond simple to me: IBIS should help the photographer obtain sharper images with non VR lenses while handheld. When using the Mechanical Shutter the images are worse than without VR, only way the IBIS works ok is by using EFCS, which is a problem in some situations as I have explained, also compared to a d850+VR lens or the Sony a7iii.
I don't see this as a war, I am trying to understand the situation of the Nikon Z6/Z7 problem.
1.Some are saying that their Z6 or Z7 does not have this problem at all.
2.Some are saying that this is the normal shutter shock with or without IBIS. Like Mirror Slap for a DSLR.
3.Some are saying that this is Shutter Shock for IBIS and it's normal even in 2019 comparing with the past cameras.
Option 2 is not far from option 3, but option 1 is far from option 3. Because if option 1 exists, I want my camera fixed, also taking in consideration that there is a recall on a VR problem.
As I said before I have took my camera to warranty and got refused because my serial number is not in the recall list. And also they did not say that the results in my tests are normal. Which kind of left me in the middle of nowhere.
I did not hijacked a thread. When I came here I had two options, to make another thread on the same situation or continue what someone started. This shows appreciation for the one who has started this thread.
I wonder if any of the sales, er, "review" sites notice this issue?
Very well said!
Because on paper the Z6/Z7 is fantastic having IBIS compared to Canon EOS R. But in real life the EOS R wins with a VR lens.
A nice option to have on the Z6/Z7 is to have the possibility to turn off the IBIS and use the lens VR when using with the FTZ. Because using a VR lens with the FTZ has horrible results with the VR on.
Also from what reviews I have seen the IBIS in the Z6 is considered better than Sony a7III, maybe it's true when using EFCS and video recording. But not when using Mechanical Shutter.
...as no new discussion is being added and folks are starting to attack each other
Status
