Tom Schum
Preliminary test results show that color temp settings do not quite match up between the camera and the light. However, it is constant light, so high e-shutter speeds can be used without danger of banding.
I need to do some more testing with auto white balance.
Panel Pro is $160. It is a true RGB rechargeable photo light, about the size, shape and weight of a smartphone. Tests were with it set to 100% power in a low-lit room.
fp L with hotshoe adapter and TTartisan 50mm F1.4 lens. Lume Cube cold shoe adapter comes with the light. There are three places on the light where you can mount it. Controls seen at top. Clip-on diffuser is shown not mounted. Without it, you get a little more light on your subject.
Lume cube and fp L white balance both set to 3000K. Lens set to F2.8, closest focus.
Lume cube and fp L white balance both set to 4500K. Lens set to F2.8, closest focus.
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Tom Schum
