Akemi
Leading Member
I never use it on my E3 as the lcd is garbage. I'd rather they did away with it and offered it as a novelty feature on non-pro cams.
"You don't like cats? You simply don't know, how to cook them..." (c)I never use it on my E3 as the lcd is garbage. I'd rather they did
Actually, a Canon SLR (EOS 20Da) had it before Oly, but Canon's was in a camera aimed at astronomy photographers.Thought this might be interesting information to see who "is" vs "is
not" using Live View. Obviously a Oly innovation that is considered a
"must" today on all DSLR's by most reviewers and by all Mfg's.
I mostly use it for stage presentations/workshops...the live view feed is hooked up to a digital projector, so the audience (which can be close to 200) can see through the viewfinder. For this use I prefer Mode A on an E-330 so the shutter isn't burned out prematurely.3. If you use it, for what subject matter or under what conditions?
Back to Oly for being first... if we can count the E-10 and E-20, which had live view but didn't have a mirror to flap.Actually, a Canon SLR (EOS 20Da) had it before Oly, but Canon's wasThought this might be interesting information to see who "is" vs "is
I discovered this use too, which makes the 330 very useful when I give talks on camera use at the local library. Sadly, I seem to have misplaced that cable. The librarian is searching for it.I mostly use it for stage presentations/workshops...the live view3. If you use it, for what subject matter or under what conditions?
Yes1. Do you use Live View (Y/N)?
Less than 5% of the time2. How much do you use it
To take shots I otherwise would have a hard time framing through the viewfinder. For example, recently I was at an abandoned mental hospital taking some photos... I had the opportunity to stick my hand through a broken window to take a shot down a hallway... I wouldn't have been able to do it (other than blindly) without live-view.3. If you use it, for what subject matter or under what conditions?
Yes. Often.1. Do you use Live View (Y/N)?
Impossible to estimate. I use it when the situation is appropriate.2. How much do you use it (percentage of shooting - like 2%, 25%,
etc...)?
LV proves to be very handy in a number of circumstances:3. If you use it, for what subject matter or under what conditions?
