Really starting to think that this is all I need to use. If I get WB and exposure correct while shooting, all I need to do is tiny bit of cropping and straightening. So here are some thoughts around a jpeg only work flow.
1. Get the best glass you can afford. After debating whether good glass is worth it or not, it really comes down to post processing. If I do everything in camera, then it is better to get the best glass. Lower end glass almost requires RAW, to allow for fixing the short comings of the shot.
2. Be able to set WB and EXPOSURE quickly.
4. Clear image zoom turns your primes into zooms, but ONLY if you are using jpeg (and video). I think this is one of the most underused features, but I love it and use it quite a bit.
5. Another way to zoom use apsc mode on the a7cr/A7Rv cameras. Whether you are in FF or in apsc mode you can get 26MP jpeg even when switching between the two modes. This is pretty clever by Sony, and lets you keep the same resolution, while giving you yet another "focal length" to use. Combined with Clear Image Zoom you can turn a 24GM lens into a > 36mm > 54mm all at f1.4.
6. Future speak, it would be nice to have LUTS to add to the jpegs in camera. LUTS that you could configure in Imaging Edge Desktop then load to your camera.
That's enough for now, and that's how I shoot my jpegs while I am shooting my RAWS (CIT being the notable exception). I almost NEVER use the RAW files unless I have a picture that is so good, but needs a bit of tweaking before sending it of to print. I just need to get comfortable enough to let go of my RAW safety net.
- For WB, I set a button up to lock white balance after locking in on the primary light source in the scene. Sony is good at capturing white balance even if you don't have a grey card, but use a grey card or white spot that is covered with the light source if possible.
- For Exposure, I set a button up to lock on a spot exposure, while using mixed exposure for the general exposure for good balance. I don't lock the spot exposure on the subject every time, sometimes you can tell the story by exposing for some other subject in the composition.
