Yes.Hi,
Is the GFX 100 II's sensor exposed when swapping lenses?
No.Or does the mechanical shutter curtain always falls in front of it when the lens is removed?
No.Is this also dependent on whether the camera is powered or not?
Thank you.
I haven't done it, but I've read about people dropping things into their cameras.Assuming that dust is the only thing that gets into the chamber (has been the case in my decades of digital photography),I think the shutter is probably more fragile than the sensor.I'm a bit surprised that if you turn the camera off, the 1st curtain doesn't cover the sensor though.
Thank goodness we don't have the issues of the FP shutters in film cameras that could, and were, damaged from either side.
the difference in fragility is inconsequential.
I get that. My concern isn't the sensor, which is protected by the cover glass; it's getting stuck-on dust off the shutter. It's extremely delicate.The purpose of closing the shutter isn't to protect the sensor from gross physical assault - as noted, the shutter itself is vulnerable too. It's just to minimize the more routine nuisance of having to clean dust from the sensor.I see what you mean. Still, I can clean a blob of something off the cover glass with no damage to the cover glass. There's no way I could clean something sticky off a shutter without wrecking it.If it were set to a check box item then the choice is there for the user with the obvious caution. I am interested in how a user might damage the shutter fitting a lens .... unless they are fitting a lens with a huge back throw unsuited to the camera, in which case they would screw the sensor anyway.
You need a dark slide somewhere in your view camera setup.I get that. My concern isn't the sensor, which is protected by the cover glass; it's getting stuck-on dust off the shutter. It's extremely delicate.The purpose of closing the shutter isn't to protect the sensor from gross physical assault - as noted, the shutter itself is vulnerable too. It's just to minimize the more routine nuisance of having to clean dust from the sensor.I see what you mean. Still, I can clean a blob of something off the cover glass with no damage to the cover glass. There's no way I could clean something sticky off a shutter without wrecking it.If it were set to a check box item then the choice is there for the user with the obvious caution. I am interested in how a user might damage the shutter fitting a lens .... unless they are fitting a lens with a huge back throw unsuited to the camera, in which case they would screw the sensor anyway.
There are people who will not change their lenses unless they are in a clean room! Well, not quite. But close. I read people saying all the time that they use zoom lenses because they won't change their lenses outside.You need a dark slide somewhere in your view camera setup.I get that. My concern isn't the sensor, which is protected by the cover glass; it's getting stuck-on dust off the shutter. It's extremely delicate.The purpose of closing the shutter isn't to protect the sensor from gross physical assault - as noted, the shutter itself is vulnerable too. It's just to minimize the more routine nuisance of having to clean dust from the sensor.I see what you mean. Still, I can clean a blob of something off the cover glass with no damage to the cover glass. There's no way I could clean something sticky off a shutter without wrecking it.If it were set to a check box item then the choice is there for the user with the obvious caution. I am interested in how a user might damage the shutter fitting a lens .... unless they are fitting a lens with a huge back throw unsuited to the camera, in which case they would screw the sensor anyway.![]()
The standard advice does seem to be camera on to lock it down. I've done it both ways (GFX 100S) and it's been fine.Hi Stan.
it’s not the physical risk I worry about when wet cleaning. It’s possible range to the IBIS system. Before IBIS wet cleaning wasn’t something I did without concern. But since the introduction of IBIS things are different. I have read some wet clean with the camera powered on as that locks down the sensor and IBIS. Others don’t. So far I have only had to wet clean my X2D once as a blower gets the job done most of the time. I use a blower powered on. With a wet clean I am always worried about applying too much pressure to the sensor package and damaging the IBIS mechanism or somehow pushing it out of alignment. What are your thoughts?
Paul
I don't know if there's a consensus position, but the Aeroclipse product that can be mailed is the one I use.For the record, what was the general consensus regarding fluid for cleaning. There seem to be more flavours than cameras. Visible Dust offers several, Eclipse, plain alcohol ? Are any considered, or reported as "to be avoided" There also seems to be an issue obtaining some of the American brands abroad as postage is not allowed.
