- Messages
- 14,512
- Solutions
- 17
- Reaction score
- 7,709
Yes, the monitor's gamut is only slightly larger than sRGB; it's not a full AdobeRGB monitor by any means. More P3, which I'm fine with.That looks like it's profiling pretty much like the monitor is sRGB.So any verification would be questionable, but I fixed the Dev drive's shutdown problem quickly, so I had a chance to install DisplayCAL from curiosity. So, FWIW, here's what DisplayCAL said in Profile info: I don't understand it, but perhaps you will.Nope, not a Dev build.Are you on build 26120.2200?Not expecting help.Apparently the Dev drive doesn't have DisplayCAL, and I see no relevant info on ccStudio. If I get around to it after I finish working with the Dev drive today, perhaps I can try to install DisplayCAL (though none of this is likely to help with your problem). :-(What I did was to run Profiler, and then check the gamut using the Profile Info utility of DisplayCal.I realized I don't have Profiler, just the low-rent ccStudio that AFAIK isn't telling me anything about what it thinks the monitor gamut is.The Dev drive isn't used for photo editing, so IDK for sure if I even have any profiling software on it, but I think I do
I'll look on the desktop's Dev drive tomorrow, if I remember.I'm on a laptop tonight.
You should be able to do the same, with ccStudio. (Or DisplayCal, for that matter.)
Verification.
26100.2161. Available to non-Insiders.
Too long for one screenshot; does this tell you anything?
Also:
Now I see what you mean; I was looking at the wrong profile when I first posted.For comparison, this is the profile provided by Philips, compared to Adobe RGB:
This is what I get from my most recent Calibrite Profiler run:
Not exactly a lethal bug, but it's annoying.
Looking at my own screenshot, the faint dotted reference comparison sRGB profile looks to me to be well inside the actual measured profile; if I have a profiling problem, I don't see it. Am I missing something?
