How to remove haze?
Sunshine_boy
Nicosia, CY
Some time ago, while using GIMP, I came across a workflow that would remove sun haze or haze due to shooting through glass. I have not made a record of it but I remember it involved layers and USM with very large radius, of the order of 50 or more. It produced very good results, giving the picture some real pop and removing the blurry, hazy effect, especially from landscape images. I am sure the same action can be done in PS and probably easier and better. Could someone please describe how he/she would remove haze in PS or point me to some tutorial that deals with this issue? Thank you
Regards
Sunshine (Fuji F30, F31, S6500, OLY C4000Z, Canon EOS1000)
Here's a method Peano posted a while back.
Fred
Assuming you have some version of Photoshop, begin by adjusting levels. Adjust each channel (Red, Green, Blue) separately. Pull the end sliders inward to the foot of the "mountain."
~ Peano
In photoshop- the unsharp method --- is just to crank the radius up alot and move the amount- to where you like it. (high radius-low amount- instead of the reverse) I usually try a curves adjustment- first.. Haven't tried the channels method-- But I will give it a shot. if the haze is bad-- you can't make a "contest winner" but of it but you can improve it.
Buzz
I normally use PWL's Shadow layer. I often find the USM method can effect pixels too much.
Regards
chip- exactly what does the pwl shadow layer do. i don.'t particularly like the unsharp technique- either it just makes a poorly exposed shot -- less poor!!
Buzz
If you have PSP, it has the terrific 'clarify' tool that seems to do a great job with haze. There has been lots of speculation about how this tool works but none of the methods I've seen posted duplicate it.
Another way is to look for methods that do a "localized contrast enhancement'. I've seen a couple of difference methods and scripts for doing this. A search on the terms here or on google should find you a couple of ideas.
In the days of Pixmantec's RAW Shooter raw converter, I used to clear up the infamous RSE/RSP haze by using 'S' shaped tone curves of varying depths to enhance contrast. The contrast adjustment in Silkypix works the same way but the sliders make manipulation of the 'S' curve easy because it has sliders for the depth and centerpoint of the curve.
RG
Thank you all for your helpful replies.
Time for trial and tests.... :))
Regards
I will almost always use Lab mode for this. An L channel curve will typically take care of it. Sometimes a mask is needed.
Ed C.
Can you explain in more detail what "Lab Mode" is and what process in more detail. I have seen a number of people reference curve adjustments in "Lab Mode" that have resulted in superior white balance and contrast.
Is this in the Paint with Light or paint with light II action? I have downloaded your actions but have yet to conquer them. It isn't you, it is "actions" I can't manage. I just tried your skinfix and it is just beyond me. I ended up with no picture--it just disappeared. I just need a good tutorial on running an action. Do you have one by chance?
Thank you.
Regards
Retouch pro web site has a tutorial on hazy landscapes that works. Here's the link
http://retouchpro.com/tutorials/?m=show&id=264
It's by Bart Hickman. You can do a web search on him + hazy landscape and get to the same stuff.
lyle
Http: sprockit.smugmug.com
Lab mode is a different way of looking at the colors and luminosity of an image. RGB is the one most people are comfortable with CMYK is one used in the printing world.
The advantage Lab has is that it separates luminosity in the L channel. It lets you adjust contrast without having any effect on the colors, i.e. no color shifts. You can sort of mimic this by changing the blending mode of a curve in RGB mode to Luminosity.
If you want a really interesting read check out "Photoshop LAB Color: The Canyon Conundrum and Other Adventures in the Most Powerful Colorspace" by Dan Margulis.
http://www.amazon.com/Photoshop-LAB-Color-Adventures-Colorspace/dp/0321356780
It can really change the way you look at photo editing, sharpening, etc. The book goes far beyond what could be covered in a thread. He goes into great detail about how to defeat haze in Lab mode.
Ed C.
If you do this on a layer [copy of background] and set this layer to luminosity, you can erase the parts where you don't want it applied. For instance a darkish tree against a light sky will cause a wide halo. Setting the layer to luminosity means yuo get the advantages of working in the L channel of lab mode wothout having to do that conversion
Hi,
USM
Amount = 25
Radius = 40.0
Threshold = 3
Cheers
Ray
quickest thing to do is duplicate layer and set the blend to softlight. You will be amazed with the result. Not enough just duplicate the new layer again.
home.woh.rr.com/chadtyree
Shoot in RAW then use the clarity slider when you open the image in ACR. I think the clarity slider is just a sharpen filter with a large radius and small amount.
Fred
~ Peano
If you adjust the R, G and B channels by different amounts, the colours in the image will end up looking very wrong. I understand that Peano knows what he's doing, so there must be more to it than what you've copied here.
Cheers from John from Adelaide, South Australia
John Harvey Photography http://johnharvey.com.au
Canon 40D, Canon 20D & Fuji F10
Local contrast enhancement is what the OP was asking about. Typical USM settings are 20%, radius 50 and 0 threshold as a starting point.
of the curve.
RG
If you do this, be careful not to block shadows and blow highlights.
A couple of simple ways to do that:
1. Adjust opacity of the soft light layer(s).
2. Adjust advanced blending options of the soft light layer(s) - blend if gray. Alt click on the black or white sliders to separate them into two wo you can adjust blending with more control.
If the soft light treatment ends up saturating the colours too much, you can reduce saturation with a saturation adjustment layer.
