How to photograph a cave ?
I went to Crystal cave at Sequoia National Park with my 40D, I used 10-22mm lens and the 28-135mm, no external flash during that time yet. I don't think it's good with flash, I think if I used AV, no flash and use Tripod the pictures will come out better but there's a lot of people and there's really no room for tripod.
those are pretty good
Here are some shots I took about 15 years ago in Carlsbad Caverns NP.
I used a Canon 35mm camera, a 20-35mm wide zoom, a tripod, a remote,
and an external flash. I can’t remember whether I used mirror
lock-up. I am fairly sure they were shot around f5.6 to f8 to get the
most depth of field. I used 400 ISO Kodak Royal film.
http://BillPPW350Z.smugmug.com/gallery/3262626_iZx8t/1/189511651_NbMeW
Depending on the light, the IS on the 17-85 and/or a monopod probably
won’t cut it. I’d go with the 10-22, a tripod, a remote, and an
external flash unit.
Hope this helps, and please post some pictures when you get back!
Bill
I’m no expert; I just like to take pictures and share them with
strangers
http://billppw350z.smugmug.com/
http://hamandcheese.smugmug.com
billppw350z - Very nice, I hope I can take some photos as good as yours.
Most people are agreeing on the 10-22 so that will be my lens in the
cave
Thanks for the kind words. I look forward to seeing yours.
Bill
I’m no expert; I just like to take pictures and share them with strangers
You always have to light the cave from locations other than your camera for the most impressive cave shots.
If you're going with someone and can get a second strob in their hand you'd be way better off than doing it all from one location.
I tried that in this underwater cave but the second strobe failed so i didnt get the shots i wanted.
Underwater cave:
http://www.divepics.ca/documents/mayanriviera2.html
http://www.stevehoughton.com
Some Cavern systems are artificially lit in select locations just for photography e.g. Luray Caverns. You are allowed to take a tripod, but its going to be hard to do long exposures as they do the tours in groups and there are little kids running about intent on ruining your shots :). A wide fast prime or the fastest mid range zoom is my recommendation. Rent one with IS, if necessary.
Shyam
