I'm just curious how well the EOS M performs using manual focus? I've read a lot about the M's poor AF performance, but not too much about its manual focus performance... (with the two kit lenses). Does the lack of a viewfinder prove a hindrance?
If you want easy manual focus with focusing aids, the EOS M is not the camera for you. Doing focus magnification on the EOS M requires too much screen tapping. First, you have to tap the magnifier icon on the screen to tell the camera you want to go into magnification mode. You'd think that first tap would get you a magnified image to focus by, but nope, it only gets you to 1X (no magnification). Then you have to tap the screen a second time to get to 5X magnification. At this time you may manually focus the camera at this magnification. You'd think that's it, right? Nope. You have to tap again to get to 10X mode, then again to get out of magnification mode. As you can see, there's a lot of screen tapping if you want to use magnification to assist in manual focus. Plus, there's no focus peaking.
Focus magnification is done much more effectively on other mirrorless systems. I have a Fuji X-E1, and this is how it's done: one press gets you in, one press gets you out of focus magnification. Furthermore, you get focus magnification
with focus peaking. In addition, what you are pressing isn't a button, it's actually a wheel that you're pressing in. Turn the wheel to the right, you get 3X magnification. Turn the wheel to the left you, you get 10X magnification. Rotating the wheel right or left will alternate magnification between 3x and 10x , whichever way you turn it. No need to cycle through 1X, 5X, 10X, back to 1X like on the EOS M.
I also use Olympus m4/3. Focus magnification can be activated with a press of a button, or simply by turning the manual focus ring. When you turn the focus ring on the lens, you can set the camera to automatically jump into focus magnification mode. Stop manually focusing the lens, and the camera automatically jumps out of focus magnification. Super easy and super simple. It's the same with the Samsung NX mirrorless system too. Samsung's system also allows other customizability when it comes to manual focus aids and how to activate them.
Canon really ought to take a look at how other camera systems implement manual focus. Not only is focus magnification so much easier to initiate in other camera systems, they also give you a lot more options (focus peaking, assignable buttons, faster cycling through magnification levels, etc.) EOS M requires far too much screen tapping. It gets in the way of shooting.
