MacM
Member
Could a new sensor expand the light spectrum for cameras? Also, have you ever thought about narrowing down a specific light spectrum, so that for example, the camera only sees from 300 to 310 NM? This is probably tricky, because the increased exposure means that there will be light leakage. The reason I ask is because narrowing down a very narrow range of light could make for higher quality, since the lens is only focusing a specific range of light. Instead of expanding spectrum, we narrow it down.
A 720nm IR filter on top of a 300nm UV filter, what light gets through? I know that it doesn't seem as though any light should be visible, except that something tells me that there is light getting through. I mean, it's not as if the glass becomes totally opaque, right?
