Kevin Attempts to Abuse a Strobe
(This from: Kevin 'Destroyer of Worlds' Horton (
[email protected]))
Just for funsies, I decided to see how much torture I could inflict on the flashlamp and energy storage capacitor from one of those little Kodak cameras. The tube was 1.2" long, in a metalized plastic reflector, with a thin metal backing to hold it in. The capacitor was 120 uf, 330 V. I hooked it up to my inverter (12 V->300 V at high current) and fired 'er up! Pop, pop, pop, pop, pop, pop, pop, (turn up trigger oscillator frequency) popopopopopopopopopopopop! It was firing about 30 or 40 times a second; it appeared as it was constantly on! I turned it down to about 15 flashes a second, and let it run. First thing I noticed was that wonderful scent of melting acrylic. Then, I noticed that the tube was kind of skewed in the reflector. The plastic was in full smoke-mode by this point. Still, the tube kept firing! (Let's see: 5 W-s times 15 flashes per second is 75 W average power, not bad for an itty bitty tube --- sam).
I left it on a bit more, and the plastic really started the smoke-signals! I noticed that one electrode was glowing cherry red. Even after all this torture, it kept going! The smoke was getting too much, so I hit the 'off' on my inverter. A few more gouts of smoke, and the little fire I created was extinguished. I let it cool down and then I examined the damage. The reflector was totaled; the tube had all but melted clean through. When I touched it, the little metal plate popped off.
On closer examination, the tube appeared to be in good shape. I couldn't see any visible damage to either the electrodes, or the glass seals. A quick test reveals that the tube still functions. As a side note, the storage capacitor got quite hot; probably around 35 degrees C. All in all, an interesting test, I must say. The next will involve connecting up a normal NE2 neon bulb and observing the results of high voltage and high current on it. I suspect it will be quite spectacular, so I'm taking precautions - It will be performed in a proper enclosure, so if the neon decides to really go 'pop', it won't do any damage.
