jack stephens
Well-known member
Are there any digicams which are able to automatically input latitude and longitude info from a gps so that photos can be labled with this info?
Jack
Jack
The only one I know of are in use by the Govt. There you can place an marker on a object and it will plug in the GPS location.Are there any digicams which are able to automatically input
with this info?
Jack
with this info?
Jack
sarhento
with this info?
Jack
with this info?
Jack
Personally what I do is just use markers on my GPS.
Take a photo, set a marker and label it with the picture number.
When I get back I can then take the GPS data place it on a map. I
have only done this a few times on flights between Toronto and
Singapore. But a kinda neat to pictures out the windows and being
able to find the exact spot on a map...
Mike
with this info?
Jack
I thought I read somewhere that you could hook up a gps to a D1X
and it would write the data in the exif info. There was a consumer
camera by Kodak that did the same thing. I don't know if it is
still available. What I do is I just take a close up picture of the
gps right after the picture that I want the gps info for. I'll have
to try the marker idea. Thanks.
Ralph
Mike
with this info?
Jack
That's what I meant when I said, the D1X has that capability.
sarhento
Mike
with this info?
Jack
Since you're using a digital camera, a cheap way would be taking a picture of the GPS screen right after your shot. Then you could rename the photo files using a system which would show you which pairs of shots belong together.Are there any digicams which are able to automatically input
with this info?
Jack
