GPH11B - streak problem
sludge21017
I'm not usually pointing at the sun 80% of the time, so I'm not too concerned... but come on GoPro!!! :-x
Pulled some other footage where the 9 had nothing, yet the 11 also had nothing (but the sun was to the left of center). Mine might be middle/right only.
received mine 10/7
my video from 10/10 has it
10/10/2021
10/10/2021
10/21
10/21
10/21, off center isn't a problem
labs, shutter angle 3x?, iso 100-800, ev -0.5
even street lights can exhibit the behavior
Hero 11+Skyreat Anamorphic Lens
less vignetting and improved coatings are claimed...I'll compare to the old one.
I do not see any new anamorphic lens on the Skyreat web site. And as far as I know Skyreat is the only maker of an anamorphic lens for GoPro's. Do you have a link?
it's not a name brand lens like a Canon or Nikon. Instead the same producer sells to multiple resellers (not just skyreat), just like many other items from China. One source on Amazon claims: "The upgraded version has no hint of vignette effects and is optically perfect. " and "Upgraded Version", plus other statements. There is also a 1.55x version I have not yet tried out.
hyperview
hyperview
Linear + HL.. strange thing is - when panning- there was a dead spot before it turned back on again. These images are in video sequence showing that.
13 seconds
13 seconds
14 seconds - off
14 seconds - off
14.x seconds - back on
Please try swapping the lens cover glass from the 10 to the 11 and vice versa, and see if the issue follows the cover glass.
So, all I can really say is the 11 is definitely EXCESSIVE compared to other models, which is probably why it is getting called out.
New sensor size?
Interesting to see it on v2 version of the H10B, but not my first one. Maybe something in the assembly process changed, or location. I know Mexico was used for some cameras for a little bit.
