Lukacs85
Leading Member
The main complaint about the 100RF the lack of IBIS and the f4 maximum aperture. I don't intend to provide a conclusion, just my point of view. One of the main reason I bought this camera is the portability. What are the main factors when we consider easy to carry around? Weight, size, and resistance against potential damages.
Each of them has a personal preference limit. That's the reason of Ricoh GR3's popularity, because in all of three aspects it's unbeatable on market.
So how a good portable camera looks like? Like a brick. The ideal carry around camera is like a thin brick, without any extensions, because easy to slide in-out an everyday carry sling, there are no extending parts prone to stuck or damage. Other advantage is the weight distribution, when you grab the camera, mass center is in your grip.
The practical purpose of a fixed lens camera, giving up the ability of using different lenses is the construction, the lens is on the sensor literally, so there is a 20-30mm size cut from the lens extension. But here is the catch, when the lens is 40-60mm long this size saving is significant. But longer the lens it's become losing the advantage. My problem with Leica Q3 is the lens bump. Yes the lens still smaller than a possible ILCE version, but beyond the limit when it doesn't matter for me anymore, because of the lens size I wouldn't take into a EDC sling, just into a dedicated photo bag.
The argument about where is your limit. Maybe Q3 is perfectly fine for everyday carry, and perhaps the GFX100RF is already too thick, even also the X100VI. But the question is, if Q3, or GFX100RF with at least 30-40mm longer lens and ruined weight distribution is acceptable for you, what is the point compared an ILCE option? Sure it's still bit smaller, has leaf shutter, but I don't think it's worth giving up the availability of different lenses.
Here is my EDC sling and the GFX100RF with lens cap, and in comparison with the adapter ring for modelling a brighter lens or stabilisation:
With only lens cap closed bag
With only lens cap:, it's on the edge of portable thickness, the hood and protection filter on left side in clothing
With adapter ring, it's too big lens bump, and worse if I consider the added weight of glass elements.
