The Fuji GFX 100RF arrived from LenRentals today for a three-week stay
chez Kasson. From the setup menus, it appears to be brand new. I’ll get to the testing soon enough, but I have a few thoughts on the design.
- It’s small. It weighs about the same as a Z7 and a small 35mm Nikkor, and it’s not all that much bigger.
- The on/off switch is too easy to move. I’ll bet some folks are going to have trouble accidentally turning the camera on when they put it into the bag.
My power switch is fairly stiff, and I do still accidentally turn the camera on but only when removing it from a bag. I assume it might loosen up over time, though. It's a mystery why Fujifilm can't do better to protect the on/off switch. They have the perfect implementation of this switch on the current and tiny X-M5 – it functions exactly the same way but it's set back from the edge of the camera body.
- The Q switch is flush. This should reduce the accidental activation of the Q switch, which has happened to me with other GFX cameras.
- Leaving the crop wheel aside for the time being, I love the way the controls work. The aperture ring on the switch has an A position which allows the exposure system to change it, which is perfect. The shutter speed dial has a similar A position. There’s an ISO adjust embedded in the shutter speed wheel that is so much better for me than the thumbwheel ISO adjustment of a lot of the other GFX cameras. And there’s huge exposure compensation dial that falls readily to thumb.
I love the controls on the RF, too. It's one reason why the X100 and X-Pro series have been so successful in my opinion.
- It looks like the lens has two knurled rings, but the front one doesn’t move. Pity.
It's the filter adapter ring and not connected to the lens otherwise. It can be removed to make the lens even smaller (and lose the weather sealing).
- The menu structure will be familiar to anyone who has used another GFX camera.
- The focus mode selection dial is flush with the body except for the part you use to adjust it.
- The joystick is not great. Fuji could do some work on the haptics. But the joystick has never been the GFX’s strong suit.
I much prefer the joystick design from their APS-C cameras. They at least should make the joystick from metal since the plastic part they have now feels really cheap.
- The front knurled dial is mushy. It needs some crisp detents. Same with the back knurled dial.
I feel the bumps as it moves, and if it were any more pronouced, it would lose its current fluidity of function when using it as exposure compensation. As much as I appreciate the rear EC dial, it's 1000x faster to set that to C and use the front cylinder dial to that function. Set that way, using A-priority with auto ISO is extremely fast to use without changing my grip on the camera.
- It’s got two SD card slots. I would have much preferred one XCD slot.
Not until Apple gives us a built-in XCD slot on the MacBook Pro.
- The lens hood is small, and that’s nice. It’s probably less effective than a petal hood, though.
I find myself shooting with the filter ring and filter and just leaving the hood in the bag.
- Now for the most controversial part of the camera, the crop dial. I’m a raw shooter, so I view the crop dial as a compositional aid, and nothing else. If you look at it like I do, it is way more prominent than it should be, and it needs a lock button.
The ratio/crop dial is the stiffest, most difficult to get to, and hardest to turn dial on the camera. I can't imagine needing a lock. I have the C position set to my favorite crop, and I can just bounce back and forth between 4:3 and C with a single click.
- The LCD tilts but doesn’t swivel. That’s fine with me.
I wish it had portrait tilt but I appreciate how flush it is when not deployed.
- The latch for the battery door is not self-engaging. Oops.
The orange plastic lock inside the battery compartment also doesn't reliably engage, but the camera still functions as long as the battery door is closed on it. I'm often opening the battery door to find that orange lock was not engaged and the battery pushed up as soon as the door opens.
- There are no detents on the SIO dial. Oops again.
The design philosophy is more akin to setting your film speed and sticking to it – or to Auto ISO.
- Access to the ISO dial by lifting a collar is brilliant.
- I’m not fond of the way the flash card access door works. Fuji could take a lesson from Nikon on how to do this right.
All the exterior doors should be metal or rubber and not the cheap stiff plastic.
- No IBIS, but then you probably already knew that.
To me, this is a modern digital embodiment of the Plaubel Makina 67 with a shorter lens. I would have preferred the lens be around 45mm instead of 35mm, but nobody asked me.
100% agree. Also reminds me of a mini version of the old Fujifilm 645 fixed lens cameras.
I am very excited for Fujifilm to give other models the new classic view metering mode and information display from the X-E5 (digital version of the film camera exposure needle).
