DaveReading
New member
- Messages
- 2
- Reaction score
- 0
I've been creating printer profiles for the last year or so with an elderly copy of EZcolor (originally Monaco, subsequently xRite). While it has its limitations, and isn't nearly as good as using a spectrophotometer, it'll do while I save up for the latter.
While profiling a printer doesn't (AFAIK) require a profiled monitor, I notice that the Monaco install adds a gamma utility that loads on bootup (though I don't recall having run the Monaco monitor calibration, so I don't know where the gamma utility is getting its calibration data from).
The Monaco install notes mention the need to remove Adobe Gamma from the startup folder, which makes sense.
Fast-forward to a couple of weeks ago, when I acquired a Colormunki Display in order to do a proper monitor profile. It appears to be working well, and the improvement is noticeable. Obviously the iStudio software loads the newly-created ICM monitor profile when Windows start, and I get a popup conforming this on boot. I see that I now have a utility called XRGamma.exe in my Startup folder.
My question is whether there is still a need to load a monitor gamma utility on bootup, and if so which one, or is the need for that superseded by the ICM profile being loaded? If I need both, should I be leaving XRGamma to run on startup and removing the Monaco utility?
Sorry if the above reflects my confusion!
