N
Nielk Mike
Guest
Let's continue the discussion with the aim of trying to figure out what's wrong and how this could be addressed by Fuji.
Fo those who have not seen AF-S issues on the X-T5 or any other models: That's fine, but I think it wouldn't be productive to continue the back and forth between "there is/there is not". No need to defend Fuji - great company, great cameras, great lenses.
Advice on how to obtain sharp images despite the AF issues has also been given in abundance. We know the work arounds, and yes, Fuji cameras can deliever very sharp images.
So where are we now:
There are reports that the X-T5 (and other models starting with the X-T1, and including the x100v, X-Pro2, and X-E3 and 4) do not reliably focus in AF-S, in particular at apertures f5.6 and up.
Mostly with lenses wider than 35mm. Almost (or completly) absent with lenses like the 50f2 or 90f2.
Aiming at the same target and repeatedly half pressing the shutter button can result in distances between 1,5m and infintiy.
The use of LM motors doesn't make a difference.
On older models like the X-T1, using just the CDAF focus points outside of the PDAF focus points doesn't make a difference.
AF-C (if the shutter is pressed without half pressign first, and AF-C set to Focus Priority) returns better results.
Checked my Sony cameras (including the trusted NEX5R) - no such issue.
What can cause this behavior (hopefully someone with technical background can chime in):
The lens? Well, while the 14f2.8 is among the worst when it comes to "AF distance jumping), the latest and greatest 18f1.4 isn't immune to the issue. But then there are some which do not show the issue at all. Prime example: The 90f2.
X-Trans sensor? In another thread (Future of X-Trans sensor) someone said he doubts that.
Large DoF with wide angle lenses stopped down? Some else mentioned this and it sounds plausible, The 14f2.8 @f8, everything from 60cm to infintiy has "acceptable" sharpness if one uses standard DoF claculators (Film Based in the Fuji world. Pixel Based is a different stoy. DoF is half, if not less, of the Film Based DoF.
So the theory is that with a large DoF the camera just can't decide where to put the focus within the area that appears sharp to the camera. So it just puts it somewhere within that range.
But it does make a big difference (in particular on teh 40MP sensor) where the camera puts the focus. 3m is different form infitniy. The are covered by critical focus changes. At Pixel Format DoF, areas that should be in critical focus may look good if not cropped, but lack sharpness when cropped in.
Two questions arise: Why does the aperture close for AF? If it creates an area in which the AF struggles to distinguish levels of sharpness, why not focus with the lens wide open? May be at the time it was thought to be a good thing if lenses displayed focus shift.
Why do Sony cameras not struggle to detect the highest level of sharpness within a wide DoF? The NEX5R closes the aperture, too. Yet it finds correct focus without "jumping". So what are the technical differences between the two AF systems?
Would find it most helpful and interesting if members with better technical knowledge could chime in.
