DS first impressions
I posted this earlier, but it fits better in this forum. I went to local camera shop and checked out the DS.
The first thing that stands out is how small it is. They had the Digital Rebel and D70 there so I compared them and the DS makes the others look really huge. I've seen the specs and pictures and yes they all say the DS is smaller, but until you see them together, you don't realize how much smaller the DS actually is.
The second thing that jumped out is the quality of the screen on the back. There was no memory in the camera, so I couldn't take pictures, but the menus were extremely sharp and clear. There's enough resolution there that Pentax was able to add 3D bevels to the backgrounds around the menu options. Not a big deal, but it is one of the best screens I've seen.
The camera was easy to hold, but I have really long fingers and it felt just a bit small. The finish is nice and the camera feels very solid. The focusing seemed very fast to me in indoor lighting. The focus indicators are bigger and brighter in the DS than the Digital Rebel which I tried out at the same time. The adjustment knob on the back felt a bit small, but was easy to use. There was a bit less info in the viewfinder than I was used to compared to the PZ1P. Exposure and F-stop are visible on the bottom. Maybe 1-2 icons were also visible. They were large and easy to read though.
The adjustments like white balance, iso, and flash mode were very easy and quick to adjust. Just press the center button on the 4 way controller, click which one you want to adjust, and then adjust it. I believe the adjustment method on the D is similar to the PZ1P where you turn a dial on top, hold the button down, and then turn the front or rear dial. I'd say the adjustments available on the quick adjustment screen on the DS are just as easy and quick to use if not more so than the D. Other adjustments were buried in the menus which were easy to use because of the nice screen, but perhaps not as quick to adjust as some of the settings on the D.
You'll notice I'm not posting any pictures. I ended up not buying it. They would only sell for the full price of $999 plus 5.5% sales tax for the kit with 18-55 lense. At that price, I would still consider a D which has more features and doesn't cost that much more. The operation of the D is also more similar to the way my PZ1P works which I am used to and like very much. The DS is set up more like a digicam with its picture modes dial, and only the one adjustment knob on the back. Also, given the size of the camera, I think a grip would have been a great option. So, I'll wait a bit and see what the impressions of more experience photagraphers are, and make up my mind when the time is right.
I was expecting results like that from my Ni-Mh AAs too. I've used them regularly on a CD player and my girlfriend's P&S. I'm going to try them again over the next few days. I agree with you about the CR-V3. I've taken probably 200 shots with them and it still reads full. It's funny but I like the fact that the battery compartment is keyed so you can't put the CR-V3s in wrong. I guessing this is normal, but it was marvelous to me. One less thing to fumble with when in low light.
NiMH need four or five recharges to work properly. I got 400 or so
shots from a well used set of 1850's.
Lithium AAs work very well and are half the price of CRV3s.
I have now taken nearly 4000 shots and I'm still on my second set
after using NiMH AAs for a while - CRV3s last forever (at least
1400 shots) so I cant be bothered charging stuff any more - the AA
Lithiums last almost as well and are a great spare since they work
in the flash too.
Agree with you about menu gibberish - you kind of get the hang of
Pentax speak after a while - and it takes a while:)
Steve
Wisdom on request
Hi, have you tested flash with your non-a lenses?
My Mz-5n (Zx something in the usa) does not read the aperture set on my m lenses, but flash meters perfectly. At least this is true as for the built-in flash. I can even use "reverse mount" (I don't know what's the english for this) on my 28 m and get macro shots beyond 1:1 with flash perfectly exposed (with a self made paper bounce, not the proper solution, but costs at all). Do you think this would be possible on the ds?
Thanks.
Enrico
Bologna, Italy.
